Electric Antenna Knock Knock
Should I be concerned with a double knock when the electric antenna on our 1983 911SC reaches is top most and bottom most positions?
1983 911SC
1954 Rolls Royce Silver Dawn
Old 03-06-2017, 08:27 PM
I'm fairly sure that is normal. I have an '84 that does the same thing.
I believe there is a ramp/clutch mechanism inside the antenna motor the slips once the mast encounters resistance allowing one of the gears move until the wire contacts are disrupted.
Old 03-06-2017, 09:41 PM
wayne robson's Avatar
antenna
As jr bennett says , that is normal, but i will tell you what helps alot
buy one of those three in one thin oil bottles,and lift antenna all the
way up,put small amount of oil on rag and rub up and down antenna
do it couple of times,it helps alot.
Old 03-06-2017, 10:52 PM
My knees do the same thing
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 03-08-2017, 06:39 PM
