Stereo wiring question
Okay, I have my Kenwood CD receiver, got the harness through a fellow Pelicanite. Here's the question, I can match up the speaker wires but the old wiring for the Blaupunkt only has a red, green and brown wire.
The new Kenwood harness has: - Red - Yellow - Black and 3 other wires marked with little tags: - P. Cont - Illumi - Ant Cont Any ideas on how I match up my 3 existing wires to all of the above?
1987 Carrera, Guards Red, Black (sold but never forgotten!) 1965 356SC Coupe, Silver on Red |
Re: Stereo wiring question
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
I replaced my Blau. w/ a newer Blau. a few mos. ago and one hitch I found is the radio ant. that is imbeded in the windshield has an amplifier that needs 12v or else your radio won't pick up squat. If I remember correctly the amp power wire was black and wrapped around the larger ant. connection, connect it to your Ant. Cont. out on the receiver (I had to change the term lug type).
You're lucky you have an Illumi Cont, that is connected to your dash light cont. so you can dim the receiver backlights (very nice). I believe if it's NOT connected the lights on receiver will stay bright all the time. HTH, Bill W.
Bill W. '97 Arena Red / Gray 993 Cab '93 968 Coupe 6 Spd '88 911 Cab Red/Blk (sold) |
GSpreeman, make sure that the red wire from the Kenwood (permanent power) is attached directly to the positive (+) side of the battery. I've known people who have tried to wire through the fuse panel and have had problems including interferance and most importantly cooking wires. Do it and be neet about it and you'll be glad you did.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
fuse that red puppy at the battery!!!!!!!. do NOT just use the fuse at the unit.
the p cont. is probably for your radio /clock memory. you can use the ant output to control an amp ( usually blue on a kenwood? ) if you add an amp, ground the head and amp at the same spot to avoid a grounding loop problem. don't let it kill your battery, if the car is parked a few days. keep an eye on it it's a sony if you look inside.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
JUST did this on my 89 930. ischmitz is very close to correct (or is correct and I'm just clarifying?)
On the Porsche: Red - switched power (ignition) Green - constant power (always on) Brown - ground so to the Kenwood you go: PORSCHE - KENWOOD RED----------->GREEN (constant power) GREEN-------> YELLOW (car on/switched) BROWN-------> BLACK (ground) the wire on the Kenwood that says ANT CONT is live when you turn the radio on and should be connected to the antenna amplifier (assuming you have the windshield antenna). The others will not be used. IF you want the dimmer on the stereo to always be dim (handy if it's got a bright display) you can connect the Ilumi lead to the RED (constant power) lead so that the unit always thinks the dash lights are on. Your other option is to run a lead from the dash lights to the Illumi lead. There's a whole other ball of wax if you have the factory amplifier installed... PCONT is power for an amplifier to be controlled by the radio unit. (BTW: This is how the wires on my radio were labeled, you may want to double check online as there may be manuals which could cause you headaches later! I can't vouch for your exact installation so grab that voltmeter and use it first!) Good luck and enjoy the tunes!
-Todd '89 930, '97 TLC (Toyota Land Cruiser), '96 T-100pick-em-up '95 BMW R100 GSPD (gone but not forgotten), '07 BMW R1200GSA |
Give me some clues on how big of a fuse I should install. I assume I can pick up an inline fuse at your basic autoparts store.
1987 Carrera, Guards Red, Black (sold but never forgotten!) 1965 356SC Coupe, Silver on Red Last edited by GSpreeman; 01-19-2003 at 05:24 PM.. |
one of gods prototypes
15 amp max, fuse constant AND ignition wires. this is only to protect the car from the radio should something fail.
did you get the other wiring figured out?
Brought to you by Carl's Jr. |
Got it up and running. Seems to be fine. I put a 3 amp fuse on the constant power wire. Will put one on the ignition wire as well. The Napa autoparts salesman said I could go with 3 amp...should I instead go with 15?
the 3 amp will be too little if you turn it up.
a 10 amp will do fine also, i don't see that head unit pulling more than 10 amps when cranked.
Thanks guys. Will get back to you when I feel the need for a subwoofer.
Thanks again.
When you DO feel the need for a subwoofer, consider the powered Kenwood KSC-WA62RC (woox), about $220. Fits on the floor in back. It's good enough for a budget-minded person like me who would rather listen to the flat-six melody anyways.
--E
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc. |
