adamnitti's Avatar
Send a message via AIM to adamnitti
Post My squeaky Porsche
Noticed today during a rally over some moderately bumpy roads that as I was decelerating to a stop, I was hearing "squeaking" from the left front. Only happened when the car was on the bumpier roads under 15mph. Is there something I need to replace or lube? Thanks-
Adam Nitti
ajnitti@mindspring.com
www.adamnitti.com
'85 911 Carrera Coupe
'72 BMW 2002tii
'97 Grand Cherokee Limited
Peachstate PCA member
Old 10-21-2001, 07:58 PM
beepbeep's Avatar
Post
Happends to me as well...it's usually rubber covers protecting interior-lights switch that is rubbing the door.
Old 10-22-2001, 12:29 AM
jsmarcus's Avatar
Adam,
As I'm sure it's been said many many times before. Just turn up your latest release a little bit louder!
Josh
'84 Carrera Coupe
[This message has been edited by jsmarcus (edited 10-22-2001).]
Old 10-22-2001, 09:19 AM
How are your a-arm suspension bushings? It is common for them to squeek if they are worn or have been replaced by polygraphite bushings. Do you get the same squeeking if you push down on the fender when the car is parked?
Paul
78SC Targa
Pelican Parts Members Gallery
Old 10-22-2001, 09:48 AM
Senior Member
Superman's Avatar
Post
That's what I've heard too. Worn front suspension bushings will squeak when they finally 'fail.'
'83 SC
Old 10-22-2001, 12:38 PM
Post
same thing happened to me. i unbolted the sway bar and lubed the bushings and the squeak went away. try it
Jason SC
Old 10-22-2001, 12:54 PM
adamnitti's Avatar
Post
no, i don't notice any squeaking when i push down on the fender. does this mean it isn't the bushings?
what kind of lube should i use? just an all-purpose moly lube or similar?
thanks again-
Adam Nitti
www.adamnitti.com
'72 BMW 2002tii
[This message has been edited by adamnitti (edited 10-22-2001).]
Old 10-22-2001, 08:32 PM
