Sound mat installation challenge
I bought an Ultimate Sound Mat recently for my Rat Rod. The car was at my Indy to replace the front/rear window gaskets so I asked them to install the sound mat while they had the car. They said they cannot because the sonds mat has a foil back, and the car has Dynamat Xtreme foil backed sound proofing not eh firewall. They claim the glue wont hold "foil-to-foil" and I would need to remove the Dynamat, which means pulling the motor.
SO......do any of the Jedi Masters here have any suggestions on how I could install the sound mat without removing the Dynamat?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-12-2017, 02:28 PM
I used 3m yellow super weatherstrip and gasket adhesive that Wayne recommends on my sound pad and that stuff really works. It worked so good that I used it to re-glue some door pockets on my sons M3. Besides if it will stick to foil on one side, why not both? Their reasoning doesn't hold water.
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 03-12-2017, 02:38 PM
Eng-o-neer
Tremelune's Avatar
The real question is why would you want both? Either leave the dynamat and cover it with CCF and MLV, or remove it all and install the sound pad.
This is in the engine bay, correct?
Old 03-12-2017, 02:53 PM
I agree which is why I asked here.
Yes it is. the Dynamat is just a layer of butyl rubber sandwiched between 2 layers of foil. It wont stop sound like the pad will. The Dynamat is already in the car and I am not dropping the engine just to remove it, and I already own the pad, so I thought why not get it installed if I can. Won't the engine bay sound pad work similar magic to the CCF/MLV you mention? Maybe not as good, but far better than just Dynamat?
Old 03-12-2017, 03:22 PM
Eng-o-neer
Tremelune's Avatar
Having never done a sound pad, I assumed the engine had to be out to get one in. Having the dynamat there certain won't hamper damping.
Old 03-12-2017, 03:30 PM
It is best if it is...that said it can be done. My car has a 3.6 in it, and it looks like that will make it a little easier.
Old 03-12-2017, 04:07 PM
Betcha can't have just 1
strudelwagon's Avatar
Another option would be to install it on the interior side of the firewall!
SW
87 Carrera Coupe 560kms (Bitza)
74 914 2.0 (Ushi)
2010 GTI (Jackie)
Old 03-12-2017, 06:28 PM
Just glue it in with 3M Weatherstrip Glue. It's not that difficult. It will take 30 minutes, and the glue will hold it forever.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-12-2017, 06:49 PM
Fast Mike's Avatar
A can of carpet glue will glue the foil pad to dynamat with no problems whatsoever.
Old 03-12-2017, 07:24 PM
May give that a try this weekend. Will report back if/when I do it.
Old 03-13-2017, 12:58 PM
This is very easy, only a few minutes with the engine in: Pad Keeper
Pad Keeper - The Solution to the Hanging Sound Pad - Rennlist Discussion Forums
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 03-13-2017, 02:18 PM
Yeah the pad keeper part is easy. The installation of the engine pad itself over a 3.6, and attaching a foil backed pad to Daynamat extreme foil backed sound deadener is more complicated. A Pad Keeper will go in after for sure.
Old 03-13-2017, 07:42 PM
