Problem Reistalling Dash
You can see from the pic the stab connectors no longer align with the plastic socket. A few were far enough away from the original location I was able to drill a new hole, so all good there. Some are just an 1/8" off and I am hesitant to elongate the hole as the socket piece will probably fall thru. Has anyone just left them out?
The dash was straigtened and recovered and the original locations must have shifted. Thanks,http://forums.pelicanparts.com/uploa...1489611506.jpg |
Can you line one up and Epoxy it in?
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 08:08 PM. |
