-   -   need opinion and help on rust (http://forums.pelicanparts.com/porsche-911-technical-forum/949758-need-opinion-help-rust.html)
Trakrat 03-16-2017 04:33 PM
OK all... I need suggestions on how to tackle this rust.
Not sure if someone makes replacement parts for this or how to fix this.
The pictures are under the passenger front fender where the oil lines run along. It's rusted pretty badly.
In some of the pics, you can see bright spots that show the inside of the sheet metal that is clean, where the outer sheetmetal completely rusted open
I'm not sure if I'm going to need a complete donor, or where to tackle this at.
http://forums.pelicanparts.com/uploa...1489710703.JPG
drcoastline 03-16-2017 04:45 PM
Trakrat,
Very common rust issue you have. It's a little hard to tell exactly how bad your the rust is from your photos. You should remove the fender and oil lines to inspect and get a better look. You will need to remove these in order to make a repair anyway.
Edit- this is also the bottom of the problem. The real issue is going to be between the flanges above the oil lines.
Trakrat 03-16-2017 04:47 PM
Originally Posted by drcoastline (Post 9514328)
Trakrat,
Thanks... I already plan on doing this... but what I'm trying to understand is if the repair will need me to find a donor part off a car, or is there some site that sells replacement sheetmetal for this?
I plan on taking it to a body shop to have them fix, but need to get the parts to them.
strudelwagon 03-16-2017 05:34 PM
This is what I had!http://forums.pelicanparts.com/uploa...1489714389.jpg
You can see the piece I removed at the top of the photo:mad:
SW
Trakrat 03-16-2017 06:10 PM
SW
interesting... did you fabricate that sheet metal yourself?
My rust is nearly all along the oil line.
I want to remove it to get a better look, but only will do so after I drive it to the body shop.
I want to make it as original as possible. Yours is obvious that it was patched.
I'm about ready to just have it shipped somewhere to get this work done, as there is NO ONE in the Midwest Kansas area that understands these cars.
Trakrat 03-17-2017 06:17 AM
Does anyone recommend some place to get this repaired?
I live in central Kansas, so I'd like to find some place within 500 miles if possible.
I want to work done to be as close to original as possible.
911Cabrio 03-17-2017 01:36 PM
Trakrat,
I have fabricated and welded in pieces before. Finding a donor car may be difficult.
Sorry, I cant help you with a referral. Trying to find a body shop willing to do rust repairs may be hard. Try to find a Porsche restoration shop.
FYI... chances are the fender flange will be rusted as well.
Good Luck, Bob
DanielDudley 03-18-2017 03:27 AM
It will look a lot better after he grinds the weld.
Contact Matt. His username is Fixer. He does nice work, and his prices are very reasonable.
Jcslocum 03-18-2017 03:42 AM
Jim at Easy might be able to supply the part cut from a donor. SF Bay Area Porsche New & Used Parts || EASY - European Auto Salvage Yard
jjeffries 03-18-2017 07:08 AM
I had to do similar work plus areas at nose where front bumper shock mounts attach to tub. Anyone contemplating this should look at Projects pictures on Classic Carreras, excellent shop in Ireland, where the cars all rust, including the galvanized ones. You will gain a solid understanding of how to approach the work. If you make patches, be sure to use the right gauge metal. Check the car's front cross member sections in front of the gas tank; indeed, removing the tank makes that easier and any welding safer. Can be a long project but worth it. More panels available from Porsche than you might imagine. John in CT.
Cook&Dunning 03-18-2017 08:41 AM
You could also try DC Auto - they will custom cut sheet metal off of a donor car - or sell you the whole inner fender. It looks like Dansk makes an inner fender, too
E Sully 03-19-2017 07:33 AM
Have you looked in the Paint and Bodywork forum?
This thread by Fishcop is a great example.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/545166-restoration-my-69-911-a.html
And DaddyGlen
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/565023-talk-me-through-rust-repair-please.html
At this point it is obvious, but after grinding and sanding it the patch can disappear.
I had no prior experience in metalwork, but have tackled similar issues on my car.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/724391-miles-go-before-i-sleep.html
http://forums.pelicanparts.com/uploa...1489936998.jpg
http://forums.pelicanparts.com/uploa...1489936944.jpg
Trakrat 03-19-2017 07:31 PM
Thanks for sharing this link!!! It has EXACTLY the kind of work I need to repair on my car!
bugstrider 03-19-2017 09:00 PM
Did you see if this section is available through Restoration Designs in Canada? They have a huge inventory.
strudelwagon 03-20-2017 01:44 PM
Yes, I did fab this piece myself. I tried to do it in one piece but the first attempt was a fail.
matching the contours of the protruding lumps using a stump with carved out contours as a buck did the trick.
Like Red Green says "if she doesn't find you handsome she should at least find you handy"
http://forums.pelicanparts.com/uploa...1490046225.jpg
:D
speedo 03-20-2017 01:54 PM
What car was this rust from?
Is this from your 1987 Carrera? Or an earlier non-galvanized car?
Speedo
Trakrat 03-21-2017 06:52 AM
Speedo
yes.. from my 87 Carrera. It was a northeastern car which explains the rust accumulating along the right/passenger side. Based on where I've found rust (and where I haven't).... it seems the car was driven after the winter roads had thawed and all of the salt and grime accumulated along the road edges. Meaning, it wasn't driven as a daily driver and driven on only nice days, but seems the previous owners never bothered to wash out the inner fenders once in awhile.
jjeffries 03-21-2017 07:47 AM
Trak....see PM i sent.
Fixer 03-22-2017 06:49 PM
I did a very similar repair a year ago for a Pelican member on his '67. The whole car must be done so this area's temporary paint is just that and will be removed and done right when I do the rest of the car's structure.
Anyway, A mouse nest between the sheet metal held moisture over the years (of barn sitting) and rusted the hell out of his strut tower. He had a donor piece given to him by I think Chris Neilson.
The key is to make the repair Strong as new but when done it can't be detected. And as important, prevent this from reoccurring. I use a lot of zinc enriched primer inside the cavities where making a repair.
Anything else doesn't pass on a 911. It requires experience welding. Spotty sloppy welds not only look bad, they are weak and allow water in. Good welding is watertight, and a good polyurethane paint (Imron) is best and even better than factory under the body Shultz.
Unfortunately, I'm too busy right now to take the car as I have a list of people waiting and limited space under roof.
But if you can wait, I can fix this so you won't be able to detect the repair and would warranty it would not reoccur.
http://forums.pelicanparts.com/uploa...1490236895.jpg
http://forums.pelicanparts.com/uploa...1490236863.jpg
http://forums.pelicanparts.com/uploa...1490236991.jpg
http://forums.pelicanparts.com/uploa...1490237046.jpg
http://forums.pelicanparts.com/uploa...1490237088.jpg
http://forums.pelicanparts.com/uploa...1490237116.jpg
http://forums.pelicanparts.com/uploa...1490237134.jpg
[/img]http://forums.pelicanparts.com/uploa...1490237312.jpg
http://forums.pelicanparts.com/uploa...1490237346.jpg
nvr2mny 03-22-2017 06:56 PM
Trakrat, I live in KC. PM me and I'll give you some names of guys that can do the repairs. They're top notch.
Trakrat 03-27-2017 12:43 PM
PM sent. Thanks!:)
WANNA930 03-28-2017 03:34 PM
You have to turn up the power with your welder you have zero HAZ and too high of a bead. Problem with MIG welding is guys insist on grinding or using 36 grit on the metal surrounding the patch. This of course makes the metal thinner then it actually is. Try blasting or at least do not use a grinding wheel.
The gap between your patch and the surrounding metal should be approx the thickness of metal being welded. Take a piece of metal and pull the trigger while adjusting the wire and power. When you hear a nice sizzle stop and check the back of the metal for penetration. If done correctly you will be right on the edge of blowing out and your bead with be 80% in the gap rather then sitting on top. Adjust the welder while it is running a bead not hit and miss style.
The welds shown are all on the top. What happens then is you grind away 75% of the actual weld and add the now grinder thin metal and it is a very weak repair. Hit a couple times with a hammer you will small cracks appear.
Adjust your welder as I said an you will see a huge difference. Only grind on the weld once you get to sheetmetal use a flap sanding disc.
Fixer 03-28-2017 06:50 PM
"The welds shown are all on the top"
Not mine:D
