RS DOOR PANEL LOCK DIAL PROBLEMS (sticks out to far)
Anybody run into this? Car is 82sc ROW. The dials don't go down flush.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
What you need to do is glue some closed cel foam on the back side of the door panel around the opening. Maybe some thats 1/4 or half inch inch thick to tighten it up.
1982 911 Targa, 3.0L ROW with Webers |
I have some left over, where are you located?
Retired Member
I had the same problem. I put foam pipe insulation behind the panel. It was maybe 1/2 of an inch thick. It worked.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Contact rennline. If that is their kit your missing some plastic spacers they now supply to push the trim ring back
83 911 Production Cab #10
I fix that problem by going with out it.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Diss Member
I can't see making the car openable with a simple coat hanger.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Formerly known as Syzygy
The opening strap has nothing to do with the locking dial. He was just showing his door panel with the dial deleted.
EDIT: Ok, never mind. I suppose the locking plunger by the vent window in his example could be opened with a hanger. Using a different style plunger that wouldn't be susceptible to that would be prudent.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 03-19-2017 at 07:21 PM.. |
In the last 7 years the roof has been up 5 times... But its a consideration.
I will definitely delete mine next time I reskin my RS panels - in 25 years I have NEVER touched those dials! I already deleted the central locking button when I removed my center console...
Chuck.H '89 TurboLookTarga, 429k miles |
