1986 911 No start
Running really strong this year until..........
Pulled it out to wash Symptoms & trouble shooting so far: 1. Cranks 2. Fuel smell at the exhaust 3. All fuses check out 4. New DME Relay installed 5. DC power to the coil 6. Does not seem to any spark out of coil I will be grateful for any input. Thanks
Flywheel sensors
wet cap
see if it dries plus one on CHT sensor |
Flywheel sensors
Then check if you get spark from the coil to a single spark plug or put the LED test light on the primary of the coil. If you see pulses but no spark from the distributor then the "wet cap/rotor" could be your problem. If you have fuel pulses confirmed but no spark pulses it is the DME. Depending on how handy you are you can attempt to fix it yourself or get it done professionally. (there will be tons of comments coming from the usual suspects once they pick the scent of this thread so I stop here) Regards, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
