LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
What is the part number for the Morelli to Bosch distributor upgrade?
What is the part number for the Morelli to Bosch distributor upgrade. The Morelli cap is pitted and past the point of cleaning.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Ignition Tune-Up | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
What year 911 are you working on??
- Casey |
1970 911T, 2.2, currently has the Morelli distributor.
Any distributor through '71 will fit and run the engine. They have various advance curves, but you probably won't notice much difference. Need to add a condenser if not running a CD ignition.
do you mean Marelli as in Magneti Marelli?
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
That's what I mean decklague.
You may have worked on this car. came from your area, was my FIL's car he gave it to our son. So any Bosch up to 71 will drop in replace?
