Part Number Help
Does anybody know the part number of the Oil Pressure/Oil Temperature Wire Harness Hold Down Clamp??
(located under upper bolt at the right hand hot air duct to fan shroud connection point) Many thanks in advance!! http://forums.pelicanparts.com/uploa...1489960020.jpg http://forums.pelicanparts.com/uploa...1489960044.jpg |
Try this number
911.106.331.00 Bruce |
I might have one.
Lorne M. |
Bruce, I think 911 106 331 00 is the bracket that receives the nipple on the rubber spark plug wire loom...
http://forums.pelicanparts.com/uploa...1489965748.jpg Lorne, I am looking for the lastest version clamp which coincided with Porsche sleeving the engine wire harnesses in the brown/beige conduit...'84 model year. My picture of the clamp (84-on) attached to the engine is the one I am after, not the one (up to 83) pictured all alone. The later one has a lot more room in its groove. Thanks so much for the replies!! |
I was looking in the pet and where it is supposed to be located.
Bruce |
| All times are GMT -8. The time now is 07:25 AM. |
