Sealant for 901 transmission gaskets
I am rebuilding a 901 transmission. Would anyone have a recommendation for a sealant to help the thin gaskets seal better? (between housing and intermediate plate for example)
Old 03-19-2017, 07:55 AM
djpateman's Avatar
AFAIK they go on dry. This is a critical location that sets the pinion engagement. The original gaskets need to be carefully measured and the exact combination put back in. Any sealant would screw up the thickness. They get well crushed anyway, so leaks should not happen.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-19-2017, 11:38 AM
It's a 914 ...
stownsen914's Avatar
Gasket thickness is critical as mentioned, and normally additional sealant is not needed. Was the trans leaking before disassembly?
Old 03-19-2017, 01:59 PM
