RSW RSW is offline
RSW's Avatar
Fuel Injection makes a ticking noise?
Can anybody offer any thoughts on this one?
The fuel injectors on my car make a ticking sound.
They sound like tappets - in fact thats what I thought they were for a long while.
I can hear the tick from several yards away - is this normal or could it be the sign of a worn injector? Or does it sound like they haven't got enough pressure from the pump?
Richard
1988 911 Carrera 3.2
Old 01-22-2003, 05:11 AM
JWest's Avatar
Normal.
James
JWest Engineering
Old 01-22-2003, 05:49 AM
beepbeep's Avatar
Perfectly normal
Thank you for your time,
Old 01-22-2003, 06:00 AM
RSW RSW is offline
RSW's Avatar
it's really anoying - i've been chasing a phantom tappet for months!!!
Thanks for the feed back.
I can't believe there so noisy.
Richard
Old 01-22-2003, 06:03 AM
beepbeep's Avatar
Take a length of rubber hose, put one end into your ear and other to each injector...they should be equally noisy.
Old 01-22-2003, 06:08 AM
RSW RSW is offline
RSW's Avatar
What if I find a really noisy one? is this the sign that it is worn?
Old 01-22-2003, 06:12 AM
dickster's Avatar
i understand you took your car to a garage?
did they sort it, what was the prob??
Rich
'86 coupe
"there you are"
Old 01-22-2003, 06:37 AM
RSW RSW is offline
RSW's Avatar
I never took it Dickster, I have aquired an osilliscope so I'm going to test the sensors in more detail.
I've also got the Air Flow/M etc.. off at the moment looking and checking for vacuum leaks in all the surrounding pipes.
I haven't given up on it yet.
Richard
Old 01-22-2003, 08:24 AM
dickster's Avatar
i wouldn't concentrate too much on vacuum leaks, it would have to be quite a leak to cause the stalling.
i assume it was still fine when cold, then stalling when warmed up (before you took, it apart)?
Rich
'86 coupe
"there you are"
Old 01-22-2003, 08:33 AM
RSW RSW is offline
RSW's Avatar
It was the same as prev described re: when cold it was better.
THe local Porsche dealer said it could be an air leak that let the car run OK when it was cold as the choke gave a rich mixture which compensated for the ammount of air then it lean'ed off as it got warm and started to play-up.
I've got all the pipes off - can't find any problems with any of them so if I get time tonight i'll re-fit and check something else.
Old 01-22-2003, 08:41 AM
