Can you change oil filter housing o-ring without draining tank?
I apologize for such a specific and novice post but this o-ring is next on my list. Can I remove the filter and housing without draining the tank first or is the oil tank full beyond the level of the housing at all times?
Rich Mason 87 951 for sale $5500 |
yes you can. when i did it, i found that the oil level in the tank wasn't high enough to leak out when i removed the oil filter housing.
You do not have permissi
Remember to clean the gasket area and what's above it well beforehand with air.
takes 1 minute to drain it.
