-   -   Strange electrical/lights problem (http://forums.pelicanparts.com/porsche-911-technical-forum/9505-strange-electrical-lights-problem.html)
motion 10-22-2001 07:32 PM
Now this one's weird:
When the headlights are off, and I step on the brake pedal, the brake lights come on as expected, but so does the right front turn signal lamp.
When the headlights are on, and the ignition is off, and I step on the brake pedal, the right headlamp and turn signal come on. The left headlamp is not on. Its new, so I know its not burned out.
Brake switch? A relay?
Let's Roll!
-Richard
'84 Carrera Cabriolet
'74 911 Widebody 3.6 Project
My Porsches
Mike the mechanic 10-22-2001 08:59 PM
Sounds like a short at the rear tailight assembly on that side. Maybe the voltage is shorting onto a parking light wire which in turn supplies power to the front parking lamp, or turn signal. Remove the tail light assemblies and check the wiring.
Mike
86 Carrera t
john walker's workshop 10-23-2001 08:30 AM
how about the old single contact bulb in the double contact hole problem? makes all sorts of wierd stuff happen.
[This message has been edited by john walker's workshop (edited 10-23-2001).]
