I have a 1976 911S Targa. The front struts and shocks are Boge and the rear struts and shocks are Koni. From what I understand I can put Boge, Koni or Bilstein shocks in the front. I can only put Koni shocks in the rear. I plan on using my car 75% street and 25% track. What would be a ideal setup, that would fit my needs?
Actually the rear should be just regular shocks, so you can put whatever you want in the back. Same shocks on rear from '74-'89.
The fronts will take any insert as long as you get the insert for the Boge strut. I just put Bilstein Sports on my '88 all the way around and they are great. My car is also a daily driver with all types of road conditions and they aren't too stiff for me. My recommendation would be to go with Bilstein Sports. Pelican has them here, http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg1.htm#item1 I did the work myself, easy to do. You'll need an impact driver to get the front top nut off and a big wrench to get the rear bottom bolt broken loose, but after that it's a breeze.
Oh, and to anyone who is interested I found the info on the rear sport/hd/sport-rallye Bilsteins as posted to the Rennlist email group by Steve Weiner of Rennsport Systems, www.rennsportsystems.com
