Is the light switch illuminated?
On 3.2 Carreras Probably SC too, the Fog Lights switch is illuminated when the fogs are turned on. Does the main light switch also illuminates? If it does how does one replace a burned bulb in these switches?
No it is not on pre '87s, what year is your car?
I'd also like to know how to replace the tiny bulb of my fog light switch. Seems so tight in there. 1988 carrera
Fog light is easy
Just peal off the rubber or gently remove plate and bulb will be exposed Use forcips to grab bulb gently and pull it out |
| All times are GMT -8. The time now is 03:21 PM. |
