-   -   a/c question (http://forums.pelicanparts.com/porsche-911-technical-forum/950842-c-question.html)
sylvester 03-25-2017 05:00 PM
a/c question
Hello. i have a question. on my 79 SC my a/c has a leak between the clutch and compressor. has any one ever had this problem. if so any advice is greatly appreciated thank you very much.
DaveMcKenz 03-25-2017 05:54 PM
Hi Sylvester,
That is a compressor shaft seal leak. It is the main external compressor leak problem. It is common depending on age and condition. The compressor can be rebuilt or depending on its other problems it can be replaced with a new or rebuilt or updated compressor.
Good luck,
Dave
sylvester 03-25-2017 06:33 PM
Ok... thank you for the reply.
kuehl 03-26-2017 05:19 AM
Is the compressor a stock York or an aftermarket?
Nick Triesch 03-26-2017 01:23 PM
I had this very same problem. I tried to replace the nose seal but compressor was shot. I bought a rebuilt unit on Ebay and it works fine. Cost was about $200.
sylvester 03-27-2017 08:48 AM
Hello.. yes it's a stock York compressor.. I'm going to open it up check it out and report back in a few days thank you.
GH85Carrera 03-27-2017 11:30 AM
Take the compressor apart to take a look see. Unless you are a super meticulous careful rebuild guru, you likely will just waste your time buying a seal kit. It is a real challenge to rebuild one and usually they have enough wear the entire compressor is junk anyway. They are not cheap, but not too crazy expensive.
sylvester 03-27-2017 12:05 PM
Ok.. I might buy a new compressor no big deal.
86 911 Targa 03-27-2017 12:23 PM
Ac pump
http://www.discountacparts.com/Porsche-911-AC_Kit-60~84594_RN.html
I bought a new pump from these folks.
I think they are in San Diego.
Great service.
Nostalgic AC - Binary Switch w/ R-134a Discharge Port 3/16" Port - AC Pressure Switch - Oil, System Flush & Switches
Also bought switch.
Best,
Gerry
sylvester 03-27-2017 01:18 PM
86 911 tanga thank you sir.
