911 front strut insert removal with strut housing still attached
is it possible to remove the strut insert with the strut housing still attached at the bottom and just swinging it down to access the top of the housing? Ive heard that it can be done.
Old 03-26-2017, 11:15 AM
I have done that before like you say. I apply masking tape to the fender lip to avoid scratches to the fender.
Old 03-26-2017, 11:43 AM
Actually I only heard that it can be done that way. Could you please describe exactly how you did the procedure? I've never done it and just want to avoid removing the entire strut housing from the car. Are there any special tools required? Is there a write up on this site possibly?Thanks for your help!
Old 03-26-2017, 01:10 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
The only problem is the brake hose. Be careful not to stress it. With the car jacked up you need to turn the steering to be able to pull the top of the strut clear of the fender. IIRC it works with some fiddling.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-26-2017, 01:33 PM
heir 2 the original owner
Franks89-911's Avatar
Yes, it can be done. This writeup helped me replace mine.
Porsche 911 Front Shock €“ Strut Replacement | RVB Precision
Once you loosen the nut in the frunk, compress the strut. You'll have to pull down the top end of the strut enough so that when it springs back up it does not hit the inside of the fender etc. Turn the steering wheel to help as others suggest.
Invest in a pipe wrench. $7 at Harbor Freight. You'll need it to get the cap off the strut housing (and to retighten the cap once you replace your strut insert).
Frank
1989 911 Carrera Targa 3.2L, all stock
"The Machine"
Old 03-26-2017, 06:06 PM
Porsche 911 Front Shock – Strut Replacement | RVB Precision
Thanks ! Im so glad i can do this without removing the housing. Ill be ordering my inserts now so i can get this done myself
Old 03-26-2017, 06:21 PM
HarryD's Avatar
I did this on my 911. Easy peasy. Hardest part was compressing the new strut to get it back in.
Be aware that there may be oil between the insert and the strut housing that will dribble all over your brakes. Be sure you cover the brake disk and caliper to prevent contamination.
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 03-26-2017, 07:10 PM
I leave some oil in the tube to help with heat transfer to the outer tube.
Old 03-26-2017, 10:05 PM
81SC's Avatar
One of the guys on PFA has just done this task & posted a how to with pictures.
911SC front shockers - Air Cooled 911s - PFA
81SC Coupe
Tony Kart/Yamaha
Old 03-27-2017, 02:25 AM
Going strictly from memory:
1. Soak strut insert caps in wd-40 overnight
2. Jack up front, remove front wheels
3. Get pipe wrench, loosen strut cap that holds the strut insert in the strut body
4. Loosen and remove nut in frunk on top of strut. Remove metal disk below nut
5. (I did right one first) turn wheel to right all the way
6. Tape off edge of wheel well with masking tape to prevent scratches
7. Pull top of strut down through body into wheel well, release, making sure when released the strut comes out and away from chassis. ( It will take force to move it and it pops back with surprising speed and force)
7. Remove strut insert.
8. Drain any oil/fluid left in the strut (mine had a ton)
9. Put maybe an ounce or two of oil in the strut for cooling
10. Replace strut insert. Reverse process to complete.
11. Get alignment done.
I also replaced the rubber "bump stop" that was on the strut insert shaft, and the new strut insert comes with new nuts and hardware for the top.
Hope that helps.
Frank
"The Machine"
Old 03-28-2017, 05:59 AM
To keep from damaging the brake hose, remove the horseshoe clip and push the metal line through the hole before angling the strut out of the wheel well.
206 637 4071
Old 03-28-2017, 06:54 AM
gtc gtc is offline
abides.
gtc's Avatar
If you have bilstein struts, you will need a punch to remove the roll pin that holds the strut insert in. Bilstein struts don't have a nut at the top.
Graham
1984 Carrera Targa
Old 03-28-2017, 01:40 PM
devalued member
juanbenae's Avatar
YES. and do this before you disconnect the strut from the top mount. will make pushing the pin out with a hammer & drift pin easier not having the top of the strut moving around.
75S slick-lid webered, early n spicy 3.oL hotrod wanna be
07.5 2500HD GM Diesel 4x/93 tuff-gong 4.oL YJ Wrangler
08 DRZ400SM+FCR Mikuni
78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 03-28-2017, 02:45 PM
