cleaning valve cover surfaces
How clean do I need to get the valve cover mating surfaces. The covers themselves are easy - but I'm curious about the camshaft carrier side. I'm nervous about bits of old gasket or scotch pad ending up bouncing around the valves.
Is it just a matter of making sure all the old gasket is off with my fingers / using a razor blade to scrape surface clean / scotch pad to actually clean back to bright aluminium?
Thanks and sorry for peppering the board with all these newbie questions.
1983 911SC
2005 911S
Old 03-28-2017, 02:17 PM
gtc gtc is offline
abides.
gtc's Avatar
Yes, just get it pretty clean and flat with a scraper or razor blade.
Graham
1984 Carrera Targa
Old 03-28-2017, 02:41 PM
If some bits get in shop vac usually get it.
87' 911 coupe- guards red/ linen leather
Only thing better than owning one is driving it.
Old 03-28-2017, 03:11 PM
Evan K.'s Avatar
I used an automotive ScotchBrite pad by hand for any residual gasket material then used a sheet of 220 grit sand paper laid flat on a piece of glass to make sure the valve covers were flat before I reinstalled them. I removed any sanding dust with simple green and water.
Old 03-28-2017, 05:21 PM
Pematex make a gasket remover. Its in a small can with the epoxy and silicone glues at any of the automotive stores. Squirt it on and let it foam. It will disolve any gasket material remaining. I use a reusable red silicone valve cover gasket.
Craig
'69 911T
Old 03-29-2017, 08:27 PM
