-   -   Help me removing Left rear HARD Brake Line please (http://forums.pelicanparts.com/porsche-911-technical-forum/951230-help-me-removing-left-rear-hard-brake-line-please.html)
fizeus 03-28-2017 04:26 PM
Hi gurus, I need help and tips.
I have to replace the left rear hard brake line because nuts at the rubber line are rusted and won't budge so I can't remove the flexible brake line
Patience, heat with PB blaster didn't help, and after too many attempts with vice grips nuts are totally rounded.
I think I have to cut the tube at the coupler to replace the entire left line. :mad::mad:
Can anyone tell if I have enough room to replace the left hard brake line without removing transmission or gearbox support?
Which is the best way to accomplish this task ?
thanks in advance
Dmitry at Pelican Parts 03-29-2017 11:25 AM
Hello - check out the link below for a guide on removing the brake lines. Hope this helps and best of luck!
Porsche 911 Brake Line Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
sixbanger 03-29-2017 12:43 PM
Vice grips and open end wrench.
fizeus 03-29-2017 04:52 PM
Hi,
I mean I have to replace Hard brake line from rear coupler to left side flexible brake hose.
(The red part in the diagram).
I'd like your suggestion on how to proceed... do I have to remove the engine to replace this hose ?
If not needed witch is the best way to put the new hose ?
Thanks in advance
http://cdn4.pelicanparts.com/catalog...ts/brakes1.gif
sixbanger 03-29-2017 06:55 PM
With out me looking under the car I can't say. What year is it. I've got my 69 here in the driveway and will take a look in the morning. It may be the same.
sixbanger 03-29-2017 07:06 PM
I just looked at it on line and I think you should be able to replace them without removal.It should be way forward. Might need to remove trans front mount.
scottrx7tt 03-29-2017 07:12 PM
I have the same problem. I just had to remove the engine/transmission for a rebuild, so I am going to address the issue while it is out. Hopefully the line sent seized on the distribution block also.
