Heater hose diameter : 1974 body, 1971 engine ?
Hello folks,
Hoping someone can clarify for me. I'm wanting to reinstall heat in my car, it's currently disconnected and missing most of the ducting. I'm going to place an order to aircraft spruce for some SCEET tubing (double wall silicone hose), but wanted to verify the diameter I should get. 1) 1971 engine, and matching heat exchangers: 2.5" diameter from engine tin to heat exchangers, and heat exchangers to flapper boxes? 2) in the boot, is it all 2.5" hose from the heater channels up to the front flapper boxes, and the boxes to vents and fresh air blower? Hoping I can get away with ordering a 10' length of SCEET and use it for everything. input much appreciated! (and my apologies, I know there are several threads about backdating heat, and what tubing to buy, but I found it really confusing as to whether it's the same across certain model years)
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
Mine is an 82 motor in a 71 body. I used the same duct for Aircraft Spruce throughout, from fan to ssi's and from the air handler in the frunk to the body.
1971 Light Ivory 911T - Gretchen - sold Looking for Engine # 6114097 2010 Cayman |
happen to recall what diameter hose you used?
Sorry, I don't. I can measure this evening and post.
Edit: A quick search tells me 2.5" (SCEET -10) is correct.
1971 Light Ivory 911T - Gretchen - sold Looking for Engine # 6114097 2010 Cayman Last edited by RD911T; 04-04-2017 at 12:36 PM.. |
I ordered 10' of -10 SCEET from aircraft spruce, will report back how it all fits!
