73 Teardown
This picture is from a couple of weeks ago, I now have the car totally stripped. My next decision is if I should go for the full strip by dipping or strip it myself. This car has had some bad body work by PO and I plan on replacing the entire rear quarters with some from a 69. I want to use the car for street and track, my reservations with dipping is that I will not be able to get every nook and cranny covered to prevent corrosion. Any insight?
Sorry, the pic did not show up. Will try again
1973 911T-working on 1964 Willys Jeep 1964 VW Sunroof Beetle a.k.a Fred 1973 VW Super Beetle-very nice 1999 Ford F350 Powerstroke |
GAFB
You didn't attach the pic.
Do a search on dipping, plus see this recent thread: Car down to bare metal It is easy enough to cover every nook and cranny with undercoating wands and attachments, or just powdercoat the car. -dtw
Several BMWs |
bump
Senior Member
Just had two fenders and loads of suspension parts dipped and know what you mean. It takes everything off and leaves you with bare metal overall. Sure cleaned them up but now like your situation they will have to be primered everywhere.
Wish there was a way to dip the car in primer after its been stripped and thus cover the hidden areas for protection! Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I got a price quote back this morning for $500-$600 bucks. Thats not to bad. This may be well worth the money just to get the car clean. How hard is it to get the main wiring harness threaded back through the tunnel? I have several pictures of the teardown process if anyone is interested.
GAFB
I'd have to rate the harness removal as the biggest pain in the ass of the job. I cut the engine harness in a staggered pattern; the connectors will not feed through the holes. Ohhh you said BACK through the tunnel. I dunno! But our plan is to run some heavy twine up through tunnel, tie it to the harness, and pull it through. Shouldn't be too bad.
Does the dipper you've found have experience dipping cars? I'd ask a few questions about their experience with unibody cars before signing up. The flushing/rinsing done after the dip is really critical. Post a link to your pics, I'd love to see 'em.
Several BMWs |
They are an industrial powder coater that has been around for a few years. I will pose that question to them. Are there any particular questions I should ask?
I'm thinking of doing the same thing and might be near you. Can you give me the name of the shop?
Chris Johnson 87' 3.4 Carrera 73' 911t restoration project |
No Problem
Beacon Industries. They are located in Seymour, Indiana (812)522-7900
Hey jb73911T
Do they do small powder coating of pieces and parts?
I'm thinking fan and stuff.. I'm near Louisville, so not too far from Semore
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
paul russel ,that restores mb's and other cars, quit dipping cars because of acids not being neutralized in hidden areas. thus rust would later form in these areas.
media blasting seems the way to go. i would dip the removable parts and then hand strip the rest. i will be facing this problem soon. if you could remove all the double/sandwiched panels and dip it you would be okay. keep us posted of your progress.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Hi Mcdaniel,
I know that the dip small parts, I had my tank from a 64 Willys stripped, I'm not sure about coating. They are very nice people to deal with though and I'm sure if you called they would help. Jim
I am working on getting all my pictures posted to my website. As soon as I do I will post a link. I have several and keep adding new ones to the collection every day. Thanks for all the replies, and info.
Jim Banks
Yep, they work like a charm! Great pics.
If you checked the thread out, I'm the one who had the car dipped. I have worked with Powder Coaters for the past 2 years with my car. Do not get your car done by a powder coater who is not experienced in doing cars. There is a big difference between a iron fence and a car.
Other than that I would do it again in a flash. But I'm not using mine for street use. That would make a difference. Paul |
RACER911RS,
I checked it out earlier and I must say you have done a great job, your car looks great.
