Carrera tensioner guards
Folks
Has anyone used these ? Any issues or concerns? http://werks911.com/products/engine-tensioner-guards Thanks all |
Under the radar
There has been some discussion on these. Probably a good idea. Of course you will have to disassemble your tensioners, which is a can of worms.
First you have to measure how much travel your piston has, then cut down the spacer to match. On my tensioners there was not enough clearance to use them. Jerry Woods Chain Tensioner Mod Carrera tensioner questions
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 02-16-2017 at 10:12 AM.. |
Thanks - my engine is apart right now so a good time for me. Will speak to my engine builder for guidance. Generally, a good idea if space to fit? I had my tensioners changed circa 30k miles ago, and recently heard what my engine builder thought was chain lash.
Shirish 1987 Carrera, Granite Green |
Under the radar
He said the tensioners were fine to re-use, however said he'd recheck them. Unsure how much give was present. He's one of the UKs best aircooled engineers, and yes, chains will be changed regardless. I didn't realise the guard Kit was a replica of the SRP Kit, should be a worthwhile mod.
So the guard kit is NLA, shame
