From 91429962993bk2914
The Final Solution... Maybe
So I am in the final stages of setting up my 914-6 conversion project with a 1982 SC 3.0 with a grind from Webcam (20/21) set at 1.9-2.2mm with .1mm lash / lobe center on intake is 1143 degrees and 112 on exhaust /
I hae a nice set of 914-6 Weber 40's very clean with new rebuild kits installed.
My question is this: What is the best combo of jets, venturi's, and other internals for initial warm up and run-in? Now is the time for me to start on the right foot / I can re-tune later but initially, I would like the best chance of a running engine to break in and check all oil cooler lines etc.
Any thoughts for experience would be greatly appreciated.
Cheers
Old 04-01-2017, 05:37 PM
Uh...perhaps a poor choice of a title for this thread?
Old 04-01-2017, 07:20 PM
never ending projects
niner11's Avatar
Not a good choice of words
Old 04-01-2017, 07:57 PM
DanielDudley's Avatar
A bit like referring to the SCCA finals as the master race.
I can't help with the jetting though.
Old 04-02-2017, 04:04 AM
Not an expert by any means but you could start with either 36 or 38 venturies, 160 mains, 185 air, F16 e tubes for starters. Maybe keep 150 mains on hand along with F11 e tubes as well.
Old 04-02-2017, 04:38 AM
proporsche's Avatar
Old 04-02-2017, 05:33 AM
https://en.m.wikipedia.org/wiki/Final_Solution
Old 04-02-2017, 07:48 AM
proporsche's Avatar
thanx tito i did not want to be so strait ..so i took off my comment..
ivan
Old 04-02-2017, 07:50 AM
