Fiberglass rear bumper valance alignment
Hey folks-
I posted this over in the paint/bodywork forum a few months ago and wanted to float it to the members here. The car is an '82 SC with an aftermarket fiberglass rear bumper (manufacturer unknown). I am curious if I can somehow re-align the area where the bumper marries up to the flares. The bumper extends too far in this area on both sides. I have no fiberglass experience but was told a little heat may get some flexibility into the piece. Pictures are below and I apologize for orientation. Any thoughts are appreciated. Thanks! ![]() ![]()
1987 Marine Blue 930 1982 911SC White Plains, NY |
That bumper was not fitted properly before painting. It needs to be sectioned and roughly an inch taken out of the center, fiberglass back together then body work and paint
Where you located?
I'm in Westchester across the TZ bridge.
I'm in cherry hill. If your willing to leave car at my place for few days, I'll do the work
Oldspool87- If you haven't seen Jimtweets work yet check it out. This guy does top notch work. He's obsessive. I have seen his cars in person. Of course the big problem will be the bumper will look better than the rest of the car so you will want him to fix the rest to match.
Option #2...
Slide it back the 1/2 inch its off, and then push out the flares with force to match... I have a fiberglass front on my 930... had to push the quarters out a bit to line up... no permanent damage or scars... |
Thanks everyone. I'm planning to install a new muffler later this month and will try to tackle this then. Do these type of fiberglass parts typicall have hallmarks or other identification on them?
