H4 midyear upgrade, question about trim ring / light housing
So i have a 1976 911s
i want to upgrade to h4 lights
question is, can i also upgrade the ring to be the short one?
tia!
top vs bottom
Old 07-01-2017, 11:31 AM
Registered Minimalist
75 911s's Avatar
Yes! 3 easy steps
1. Grab 800 dollars!
2. Buy and install H4s - there are several options - Pelican, Pelican classifieds, and 3rd party sites.
3. Don't forget the JWest relay upgrade while you're in there!
4. A whole new world!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 07-01-2017, 12:17 PM
Formerly known as Syzygy
Canada Kev's Avatar
Just so I understand, you want to change the headlights from the ones like on the silver car to the ones on the black?
The black car has Euro H4s (which can be ordered in either matte black or chrome rim) with a paintable trim ring that covers the black or chrome rim of the headlight.
H4 headlights are also available as a retrofit direct replacement for the sealed beam lights in the sugar scoops on the silver car.
Kevin
Old 07-01-2017, 12:21 PM
Originally Posted by 75 911s View Post
Yes! 3 easy steps
LOL on #1!
Yep, 75 911s is correct--you have to buy the complete assemblies to get rid of the sugar scoop trim rings. Otherwise, you can keep the old look and replace the 7" sealed beam with 7" insert that uses an H-4 bulb. Those run around $45 each.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-01-2017, 12:30 PM
Ahh so that's the difference. I want to keep the chrome look but the shorter rings.
I'm already aware to get all new gaskets and the relay
Old 07-01-2017, 01:20 PM
Canada Kev's Avatar
Ironically, if you want the Euro H4 assemblies, the chrome ring lights are actually cheaper (from our host) than the black rings. And even more odd, the Porsche branded lights are less expensive than the Automotive Lighting ones.
Kevin
Old 07-01-2017, 03:34 PM
are the euro ones that much different for 120 more a light? or is it just the cutoffs.
do the buckets need to be replaced? and any advise on h4 bulbs or just the oem ones.
ok so here's what i have.
the lights with the rings
Headlamp Assembly 91163111300 - Genuine Porsche - 911-631-113-00 | Pelican Parts
relay
Headlight Relay Kit JWST911HLPR - JWest Engineering - JWST-911-HLPR | Pelican Parts
some bulbs
Headlamp Bulb 99963103490 - Genuine Porsche - 999-631-034-90 | Pelican Parts
and some new rim seals
Headlamp Rim Seal 91163111502 - Genuine Porsche - 911-631-115-02 | Pelican Parts
Old 07-01-2017, 04:06 PM
Importec has them for $322 each with chrome rings. It's a complete assembly not just lenses and trim rings.
Old 07-01-2017, 04:44 PM
