Some questions on my '74--G or H?
Trying to learn more about what I have, and I see conflicting info on the interwebs.
* Build date is 7/74, so is it a G series or H series? * Most pics for a '74 show a 4-spoke steering wheel, but this one has the three-spoke. Was that an option for 1974? * Apparently the 911 "base" was a '74 year only model. Any way to determine build quantity for the base '74? * Mine is black with the blue/black interior. That was apparently not a standard color option. Any way to find out how uncommon that might be for a '74? * Was the passenger side mirror an option? Thanks for any expert input! |
Post your VIN and I can answer your questions.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Will do. That should help with the first question at least.
Registered Minimalist
G series (8/74 begins H)
3 spoke is the Carrera wheel. Probably swapped if yours is a 911 or 911s 911 (Base as you call it) 4014 units Blue is a standard interior color (vinyl) Right side mirror option is M093 (manual) m261 (power)
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
So I guess there was a very short run of short-nose G-Series 911s. 3 spoke is the Carrera wheel. Probably swapped if yours is a 911 or 911s Quite possible. Didn't know if it was a factory option or not. 911 (Base as you call it) 4014 units Assuming most were painted standard colors, black might be semi-rare lol Blue is a standard interior color (vinyl) Thanks. Right side mirror option is M093 (manual) m261 (power) Thanks. |
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
