proporsche's Avatar
Porsche 911 1985 Cylinders
hi Boys..
I have a Q...has anybody done this to theirs cylinders ? I have an option from one machine shop in Germany to cut a groove into a cylinders to use sealing o ring alu. made.Like it was in early 911`s.The alu.ring i was told is self made by this company.
It is for 911 1985 Carrera with 80 000 miles.
I do not know anything about this update so, if anyone would have an idea or done this i would appreciate any hints.?
Do it or not?To be or not to be?
thanx
Ivan
Old 04-03-2017, 02:56 PM
proporsche's Avatar
ops sorry wrong place...
Old 04-03-2017, 03:01 PM
I've had that done to 1990/1991 cylinders. Trim the top from the outside in until the o-ring fits, and not too deep so you get some crush on the ring. Works fine
206 637 4071
Old 04-03-2017, 04:46 PM
proporsche's Avatar
Thanx John -understand but this is for 85 Carrera..
ivan
Old 04-03-2017, 11:36 PM
Hilbilly Deluxe
emcon5's Avatar
What problem is this a solution to?
82 911SC Coupe
GTI Cup #43
Old 04-04-2017, 08:54 AM
proporsche's Avatar
Hi Emcon..i was told by the German manufacturer that it prevent future oil leaks under the heads.
I personally never had a problem of oil leaking there.
I am sure John will explain better..since i have never had it done to the engines i have built...
Ivan
Old 04-04-2017, 09:34 AM
I had a problem with leaks there on an 86. I did the mod you refer to and used CE rings like on an SC. Worked fine, but I now believe they are unnecessary.
-Andy
Old 04-04-2017, 06:14 PM
Hilbilly Deluxe
emcon5's Avatar
I am having a hard time picturing where oil would come from that would leak there, and maybe I am missing something, but if you are leaking oil there, I would think you would have bigger problems than that ring would fix.
I guess if your rings were shot, allowing oil from the case above the pistons, or maybe horribly leaking valve guides, or a cracked head oil could leak there.
Is there something else I am missing? Is there some other explanation for having enough oil in the combustion chamber to leak?
82 911SC Coupe
GTI Cup #43
Old 04-04-2017, 10:31 PM
proporsche's Avatar
Hi Emcon..sorry i have written is wrong..It keeps the pressure on cyl. so they do not leak under the cylinders..again the best is John to explain;-)
Ivan
Old 04-04-2017, 11:23 PM
