| Registered Join Date: Nov 2003 Location: South West Florida
				Broke a caliper bolt, now what
			Well I decided it was time to do the brakes and rotors on the old boxster so I ordered all the parts from pelican of coarse. Did the rears, no problems, got to the left front and man those caliper bolts were tight. I of coarse grabed my long 1/2" torque wrench and figured that would do the trick. Well obviously the bolt broke. It started, but continued to be difficult. Then it snapped. So what am I looking at to get the bolt out? I'm going to just go ahead and call a local wrench and let them fix my screw up. But what's the trick? Both bolts are frozen in there, except one is missing the head.
				__________________ 2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 | ||
|  04-02-2017, 10:39 AM |
| Registered |
			I broke a caliper bolt on a commuter car once.  The bolt went through the spindle and then into the caliper bracket.   The spindle hole was not threaded. So, all I had to do was to drift punch the bolt shaft out of the spindle hole. The caliper bracket slid off with the bolt shaft stuck in it. I replaced that part, since there was no way that busted rusted bolt was even coming out. Not sure if your car has the same design, but just verify. With the bolt head off, the caliper might come free of the hub/spindle, and come right off. See how the 2 holes on the left are not threaded?
				__________________ 1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-02-2017 at 12:05 PM.. | ||
|  04-02-2017, 11:39 AM |
| Registered |
			Incidentally, what is less likely to shear a bolt? Impact wrench or breaker bar?
				__________________ 1986 Bosch Icon Wipers coupe. | ||
|  04-02-2017, 11:41 AM |
| Registered |
			Apply heat to the one that isn't broke and drill and re-tap the one that is.
				__________________ 1984 3.2 cab india red 1970 1192 Volkswagen Beetle | ||
|  04-02-2017, 01:34 PM |
| Fleabit peanut monkey | Quote:
 Another incidentally, are the caliper bolts stretch bolts?
				__________________ 1981 911SC Targa | ||
|  04-02-2017, 01:41 PM |
 However, check out what sugarwood suggests on the bolts.
				__________________ 1981 911SC Targa Last edited by Bob Kontak; 04-02-2017 at 01:47 PM.. | ||
|  04-02-2017, 01:44 PM |
| Registered |
			Is there any advantage to the breaker bar?  Always use impact if you've got it?
|  04-02-2017, 01:47 PM |
			The caliper bolts to the spindle.  I guess ill find out soon.  I'll call a shop tomorrow and let them know what I need.  I moved down here 3 years ago and have never needed to use anyone so far.   Hopefully they won't mind useing the parts I have already purchased. And will take care of a new customer.
|  04-02-2017, 02:08 PM |
 I would have probably done what OP did and used a breaker bar. It's a decent size bolt. Using a breaker bar though takes some "experience" to check out if it's going to work without twisting the bolt shaft off. There is usually some kind of pop as the crud lets loose. When you shear, it moves and there is no noise. It's time to stop and get heat and PB Blaster. I have twisted plenty off but none or few with an air wrench.
|  04-02-2017, 02:31 PM |
| Registered |
			Did you get my first reply?   You may be able to remove the caliper, since the bolt head is gone...  Find out if the spindle is threaded.
|  04-02-2017, 03:08 PM |
			The spindle is threaded.  I could get the caliper off by breaking off the other bolt.  But i figured I could drive a few miles with the one bolt still holding the caliper on.
|  04-02-2017, 05:09 PM |
| Registered |
			I agree it is less stressful to just punt before you make it worse. But, if the spindle is threaded, then how would you get the caliper off by breaking the other bolt head? Both bolt shafts will still be threaded into the spindle. That would be near impossible to remove. Are you 100% sure the spindle is threaded?
|  04-02-2017, 07:20 PM |
			The bolts slide through the calipers and screw into the spindle.   The rear bolts were threaded all the way to the head. I'm wondering if they couldn't put two nuts on and with heat be able to back out what's left of the bolt.
|  04-02-2017, 11:16 PM |
				 | The caliper bolts to # 1.
|  04-02-2017, 11:52 PM |
| Registered User Join Date: May 2011 Location: Los Angeles
			Hi. Here is some cool technology you may want to consider: https://www.google.com/?gws_rd=ssl#q=edm+to+remove+broken+taps&*&spf=210 Good luck, Bill. | ||
|  04-03-2017, 07:16 AM |
			I dropped it off at a local shop.  They didn't seem like it was a big deal.  I'm going to a air show tomorrow, Sun-N-Fun, so they can deal with it. Hopefully it won't cost to much to fix. After dealing with aircraft shops and mechanics I've gotten kind of numb to repair prices.
|  04-03-2017, 12:04 PM |
  I bet under $200. Have them pop the other side loose as well.
|  04-03-2017, 01:24 PM |
| Registered User | |||
|  04-03-2017, 03:25 PM |
| Paper Member Join Date: May 2005 Location: trumpistan
			This happened to me too. I bought a used bearing carrier on eBay. Sent from my iPhone using Tapatalk
				__________________ Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. | ||
|  04-03-2017, 04:34 PM |
It is probably over 35 yrs old and was a cheap model.  I have a better one now.  I just keep it around for times like this.
|  04-03-2017, 05:45 PM |
