Wire ID
What is this wire fornon the 3.2 motor harness?
Hi this topic was just here a day ago..it is your connector for engine heater motor..not plugged in.
Ivan |
Member 911 Anonymous
Make sure motor is not toast before you leave it plugged in, it could start smoking. Must be a reason why PO disconnected it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
The one from the heater fan is coming from the relay box , this one is coming from the alternator / shroud area . With a yellow black and brown wire
Just curious, isn't that the engine "cooling" motor? Comes on when the engine is hot after being shut off? Maybe it also comes on when the heater levers are pulled up. Just asking. Thx.
Sold: 1989 3.2 coupe, 112k miles |
