Gordo2's Avatar
Help!!! Porsche 915/73 Main Shaft Rear Bearing Race Removal
Ugh!
I'm trying to remove the main shaft bearing race that fits into the differential housing on the 915/73 transmission (the smaller main shaft bearing - http://www.pelicanparts.com/More_Info/93030239101.htm?pn=930-302-391-01-M260). I'm replacing the bearing, and it comes with a new race - which I understand should be used / installed with the new bearing...
The bearing's outer race is pressed into the differential case, and is kept in place by a small circlip (that doesn't have any means to grasp) on the differential side of the race (keeps the race from moving toward the differential):
For the life of me - I can't remove this circlip - I've been fighting with it for the past hour and a half, with small picks and stuff - but can't get it out.
I can't see how I can press the bearing race out without removing this circlip and I'm getting beat trying to remove it.
Appreciate any thoughts on what I can do.
Thanks,
Don "Gordo" Gordon
'83 911SC Targa
Old 02-04-2017, 11:50 AM
Porsche Wiki
look up Peter Zimmerman and google up his How-To: Porsche 915 Transmission Repair Tutorial must read if you are in this deep good luck and call Peter
Old 02-04-2017, 02:57 PM
with a small screwdriver get behind the clip in the open slot get it started out of the slot and work it out around the groove
Old 02-04-2017, 03:00 PM
Gordo2's Avatar
Harbor Freight to the Rescue
Went to Harbor Freight and picked up some larger picks.
I ground the pointed tip to an angle on the large 90° pick - which allowed me to get under the lip of the clip and use the 90° angle of the pick to leverage / pry against the case.
Gotta have the right tools, and in spite of this one being a cheap throw away - it did the trick...
Onward - Gordo's 915 Transmission Rebuild
Gotta have the right tools, and this one did it.
Thanks,
Don "Gordo" Gordon
'83 911SC Targa
Old 02-05-2017, 08:52 AM
Brew Master
cabmandone's Avatar
SWEET! Glad you got it!
Old 02-05-2017, 10:45 AM
Bill B
FWIW I took a different approach (after struggling similarly). I couldn't remove the snap ring but i could rotate it in its slot. Therefore i tapped on the bearing through the gap in the ring, then i would rotate the ring 90 or 180 degrees and tap again. Repeat, repeat... I used a relatively short round headed (hex driven) bolt as my "punch" because it didn't have any sharp edge to scratch anything. It worked nicely.
Old 04-29-2017, 10:08 AM
Gordo2's Avatar
Gtg
Originally Posted by billb123 View Post
FWIW I took a different approach (after struggling similarly). ... It worked nicely.
Nice work - I didn't consider that approach (I was obsessed with getting that clip out).
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-29-2017, 07:40 PM
Heat the case and they almost fall out.
206 637 4071
Old 04-30-2017, 07:24 AM
