91 964
Question switched 12v needed for a 964 C2
I am looking for a source of unfused but switched (on with ignition) power. Out of the ignition switch itself would be okay - anyone know an "easy" place to tap into this?
Old 06-13-2014, 06:16 PM
I would probe the fuse box and find a circuit that is switched .If you don,t want it fused connect to the supply side of the fuse you end up using.
Consider what amperage you are drawing and if much more than the circuit you tap , you could add a relay and only use your switched supply to trigger the relay. I would also use an inline fuse to protect the new wiring
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-13-2014, 06:36 PM
91 964
Thanks John, That is exactly what I will do.
Old 06-13-2014, 06:38 PM
Suggest you confirm the desired circuit with its branch circuits can provide sufficient current for your accessory w/o overloading the circuit.
Obtain a circuit diagram, then trace the source path from the desired fuse to ground while noting the loads attached to the branch circuits (e.g. cig. lighter, blower motor, rear window defroster, etc.).
What are you attempting to connect?
Sherwood
Old 06-13-2014, 06:45 PM
91 964
Sherwood, i actually need a location with nothing else on it - basically straight from the key. I have all the diagrams etc but was hoping there was a simple way to attach to the key. I have actually just installed a gm e-rod v8 in my 964 and need to hook up the main ignition/keyed source for the system. The constant 12v was easy in the back.
Gavin
Old 06-13-2014, 07:53 PM
Gavin
Why not just use the factory 12V ignition systems source wire that's already in the engine compartment?
Find the color coded ignition source wire in the factory electrical schematic.
Sherwood
Old 06-14-2014, 01:51 AM
91 964
That was actually my original plan but in talking with others who have done this they all say they come off the key itself. I assume it is to insure the gauge of the wire and that other loads comes off of it. Have to admit that, in spite of all the wiring I have done I still worry about getting this right which is why I decided to ask on this forum.
Old 06-14-2014, 06:01 AM
Now that I know what you are trying to do. I would also suggest using the original ignition supply wire in the engine compartment.
It does come directly from the key and is already in the loom.
1995 993 coupe
2012 Boss 302
Old 06-14-2014, 06:12 AM
91 964
OK I hear you guys. I will do that.
Old 06-14-2014, 06:40 AM
Platinum Member
dad911's Avatar
Or use the ignition circuit to switch a relay, if worried about drawing too much current through the ignition switch.
Old 06-14-2014, 06:54 AM
91 964
Dad911, That seems like a great, simple idea.
Old 06-14-2014, 07:12 AM
When the expensive Porsche ignition switch fails, it's usually in the start or crank position. Using a separate switch and relay to perform the actual switching to the starter will extend the service life of the ignition switch. FWIW, here's my remote relay mod.
Remote Starter
Sherwood
Old 06-14-2014, 08:47 AM
91 964
Hey Guys, just thought I would give you an update on what I did in case anyone else is in a similar situation. The e-rod computer needs to control the fuel pump - it has a "fuel pump out" wire, so I hooked that up and used the 964 fuel pump power as a switched source for the e-rod computer.
Old 10-19-2014, 06:05 AM
I am looking for a similar answer/solution to a 12v switched power source in the engine bay. I am not exactly sure where the fuel pump switched source is in the rear. Does anyone have any ideas/suggestions?
Thanks!
Old 04-10-2017, 10:02 AM
3rd_gear_Ted's Avatar
Here is what I mounted in my car.
20 amp in line fuse on main input post
when you track your car, you find needs lots of 12 vdc stuff.
Helmet blower
ECU
Cool Suit
On board transponder
fused portable air compressor 12 vdc source for pit adjustments
Comm
230896
1980 911 - Metzger 3.6L
2016 Cayman S
Old 04-10-2017, 10:53 AM
Helmet blower
ECU
Cool Suit
Comm
230896
That'll be useful to use, but only once after I figure out which wire is the 12v switched wire to connect to! Haha.
Old 04-10-2017, 11:17 AM
ROW '78 911 Targa
timmy2's Avatar
Don, what year is your car?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-10-2017, 11:33 AM
My car is a 92 C4.
I've been trying to read the service manuals, but either I am not able to find the correct page or also very possible that I just don't know how to read the wiring diagrams that well.
Old 04-10-2017, 11:45 AM
ROW '78 911 Targa
timmy2's Avatar
Too new for me, my manuals stop before 1990. ...
Dennis
Old 04-10-2017, 12:00 PM
