-   -   Possible rear CV Joints need help (http://forums.pelicanparts.com/porsche-911-technical-forum/952875-possible-rear-cv-joints-need-help.html)
rekstein1 04-10-2017 04:24 PM
Help Guys! 1988 911 Cab that I pulled out last week to drive this early spring.
First week no problems was on the way to a great summer. This week inside the cab it got very loud. Had to turn the radio up to hear it decently.
Wife got in the car this past weekend and said it was loud inside and that something is wrong. Brushed it off and today it got louder.
It seems to be coming from the rear. There is some vibration at 50 mph and higher and just a loud noise as well . It get less loud as the speed decreases down to 30 mph. Can barely hear the engine inside the cab like before.
Crusing along at 50mph took the car out of gear and there was the sound it was just loud and seemed to be in time with the rotation of the wheel. Did the slalom thing up and down the road with the car out of gear and heard nothing.
How does one check for bad CV joint in the rear? Anyone have any thoughts or encounter this? Where do I start looking for the sound?
Was going to put the car up on jacks and spin the wheels to see if I hear something:confused:
Your thoughts welcomed
Jeffreypang911 04-10-2017 04:29 PM
Jack it up and check it by spinning the wheel, maybe you blew a cv joint in the rear. Its happened to me before! SmileWavy
yelcab1 04-10-2017 05:00 PM
If it is that loud, you should be able to hear it with the car in the air an spinning the wheel.
rekstein1 04-10-2017 06:39 PM
If it's a cv issue buy the whole axle or repair the one I have?
Joe Bob 04-10-2017 08:27 PM
https://www.facebook.com/groups/284744841583679/
Joe A has axles and CVs for sale.
Bill Douglas 04-10-2017 09:23 PM
While you have the car jacked up to check the CV joints; check the gearbox oil while you're at it.
T77911S 04-11-2017 03:35 AM
could be a wheel bearing.
to me bad bearings sound like what I think a "dry" bearing would sound like. kind of a "rough" sound.
most CV joints (other cars) I have heard have a clicking sound. the higher the angle a CV joint has the louder or worse it will sound. like a front wheel drive car. fairly quiet going straight but turning they are extremely loud.
with that said, I would think a 911 CV would have to be extremely bad for it to be really loud because the angle on the joint is not that extreme. just a speculation since I have never heard a bad 911 CV joint.
check the boots. if any are torn and no grease, that's not good.
the other you can do is
what I did on my 930 was jack one side just enough to get the wheel off the ground. start the engine and put it in gear. let the clutch out slowly and unless you have an LSD, it will spin one wheel. you can do each side.
be very careful if you do this.
my bet is a wheel bearing.
they were so bad on a BMW I bought you could not even talk in the car it was so loud.
Duc Hunter 04-11-2017 03:50 AM
Just a side note look at the tires too. I had this happen once and realized the tires we worn in a fun way. In my case, for some reason, the tires over a winter just decided to give up. When I started driving in the spring they wore really fast and changing them made the car quiet again. Just a thought, though it sounds more likely to be a CV.
AC78 04-11-2017 03:51 AM
Apologies for thread hijack, but what is the general consensus on replacing CVs - renew existing hardware, or purchase new CV and axle assemblies from Pelican?
I enjoy wrenching on my car but repacking CVs looks like a horrible job. Also my CVs and axles are near 40 years old now so am leaning towards a whole new assembly.
Would be curious to hear other people's thoughts on this.
Cheers
Joe Bob 04-11-2017 03:56 AM
Dirty filthy job repacking them with grease. High failure rate. New CVs and axles are the fastest way to go. PP used to sell them, my last replacement was thru Eric at pmbperformance.com.
EDIT: To clarify, now that I have had my coffee and BP meds....the CVs and axles are one pre-built component for each side. They are a simple swap with the need of a few small easily obtainable tools bits. If you are a competent DIY person easy. If not a search will find many threads and hints on the subject. If you need a hand, many PP members have been known to drop by and help. I am willing to discuss on the phone with you if needed.
CV failure is predicated by a clicking sound. Bearing failure but loud whirring noise. If not sure, most independent alignment shops will give an opinion on the subject and an estimate for repair. Since I do my own repairs, I have no idea what a shop would charge for parts and labor.
CVs can fail with an intact boot due to high mileage, a torn boot that spews out grease or just age. Don't go with the cheapest CVs as you will likely re-visit the replacement again soon. Not rocket science to replace but there is a significant grunt factor involved and some tricks if the Castle nut hasn't been off in a while or you drive in a snow and rain environment.
Bearings, there are cheap and more pricey bearings. They can be a bear to remove, read up on the R&R of them. Be advised, swearing can be involved, there is more than one way to remove them, consider renting or borrowing the "right" puller. Be advised that the hub race can be damaged if the bearing is really far gone. YES, Use the freezer on the new bearings to aid in easy slip in. Do not force them in. They can be damaged in installation. Easy is good, force is bad.
CVs can be rebuilt, repacked and reused. But CV grease besides transmission fluid is one of the nastiest "used" fluids known to mankind. The smell and the feeling on my hands, even with protective gloves, just sets my teeth and nose into flux. After all the grease/fluid IS a hazardous material of a sort. Designed to handle high heat and can't be a good thing to be in close proximity to. If you insist on tearing the CVs down, be advised that the ball bearings, the cage, snap ring, boot, outside fasteners are like a Rubik's cube. I'd rather deal with Quantum Mechanics while listening the Rush Limbaugh and the dittoheads sing "OH Tannenbaum".
Good Luck, report back.
Franks89-911 04-11-2017 04:03 AM
Cheers
I replaced one when I found a boot had been torn sometime during Dad's life/ownership. I don't have the time, knowledge, or capacity to disassemble, repack, etc., and not knowing how long the car had been driven like that, a simple replace was my choice. All I had to buy was the 32mm socket for the wheel nut and an 8mm hex nut for the bolts on the inner side. Maybe 1-2 hours labor per axle. Surprisingly easy. Hardest part was getting enough Newtonian force on that wheel nut to get it off.
Jesse16 04-11-2017 04:52 AM
Bearing, not CV
I like the idea of a bad wheel bearing myself. Usually described as a howl or growl noise. If the CV boots are still intact and no outside grease is visible then its unlikely one is bad enough to make a constant noise. As others say, you should be able to diagnose with wheels in the air and turn by hand. Take a good look at everything. If you have a bad CV boot, whether to buy the rebuild kit from our host (grease, new boot and clamps) or buy new is simply your interest in a messy project and cost saving.
You also have to buy or borrow the tool cinch the pinch clamp. I rebuilt mine after boot tears and they continue to work fine.
charwood77 04-11-2017 05:02 AM
My bet is wheel bearings. When my rear bearings went bad it sounded like I was piloting a cesna.
Joe Bob 04-11-2017 05:04 AM
Depending on the tubs mileage a CV AND bearing replacement would be good idea while you are in there. Mine failed on both sides within 500 miles as I have an LSD transmission and had a high HP motor swap and tracked the car.
McLaren-TAG 04-11-2017 06:55 AM
To the OP, it helps a ton when you describe the type of sound. Just saying it's loud is why you're getting the scattershot of responses.
CV joints do make a wooing sound especially when under larger angles like going through a slalom. Bearings make like what was described, a loud bearing sound. Have you gotten under the car to look? Have you lifted the car up and spun the rear wheels to see if there is noise and where it's coming from?
Most of the stuff back there is easy enough to fix but one thing you said worries me... you heard the sound and just ignored it. That's never the right thing to do, it never ends well and the more you neglect things the worse they get.
T77911S 04-11-2017 06:58 AM
CV's are pretty robust.
messy job might be an understatement. just did all 4 on my 930, boots and grease that is.
they also need to go back together a certain way. that is the inside cage needs to go back in with relation to the outer part.
then the CV needs to go back on the axle the correct side out.
its not hard, just messy.
I would definitely replace all the washers. bolts are up to you as long as the ones in there are the correct length. 2-3 threads should stick out past the flange.
threads also need to be clean.
you DO NOT want a joint coming off while driving.
you can get bolts and washers from Fastenal. bag of 50 is still cheaper than buying the correct amount individually. they also come in 5mm lengths.
boots are another issue.
just saw a post about an alternate boot than original.
also, you can get the pliers to clamp the original type clamps at advance for about $10. .
did I say it was messy
Luccia at Pelican Parts 04-11-2017 07:41 AM
I've had wheel bearings exhibit some really strange symptoms and sounds before. How many miles are on your current ones? As the mileage increases on the car, heat and lack of lubrication can cause the bearings to wear and possibly fail. I have even had a few that don't have the typical howl/growl sound or weren't very pronounced when putting load on one side. If you're savvy enough and can grab a video of the sound it might help a bit. Also, I have seen vibration be contributed to bad axles before. Otherwise, lots of great advice given already on how to diagnose the issue. Let us know what you find out.
If you do decide to replace the bearing - FAG, SKF and Genuine are all good brands to go with: 1988 Porsche 911 Carrera Convertible - Axles, Bearings & Differential - Page 5.
If you do decide to replace the axle - GKN is the OEM supplier and I've had great success with them personally. Otherwise we have Geunine as well - 1988 Porsche 911 Carrera Convertible - Axles, Bearings & Differential - Page 1
rekstein1 04-11-2017 03:54 PM
Tuesday's update: Got the car jacked up and spun both rear wheels individually. No grinding sounds, wheels seem to spin seemingly freely. Looked at the axle boots no grease anywhere , no torn boots. Current Mileage since it was asked is 150,000k. Got the car at 110,000. No great paperwork before this.
I saw a post where it was suggested to jack up the whole back, start the car and run the wheels. As the author suggested this is risky. NOt up to doing this as I don't want to do body work on the hood.
Barring any other tests anyone can suggest I think its time for a professional look.
Anyone have any suggestions?
Didn't check the front wheels as I think of it. But I could swear the sound was coming from the rear. Will check the fronts tomorrow as it is dark now
Appreciate any thoughts
Bob Kontak 04-11-2017 06:04 PM
Was the car on jack stands and did you have your hands on the wheel drive shafts feeling for anomalies while you spun the wheel? Or, did you jack one side up and spin the wheel from the outside?
T77911S 04-12-2017 03:29 AM
I have done both.
had car on jack stands and ran it in 1st gear.
also put a jack under one side and ran it.
other option is to remove the wheels and pull the brake pads out and turn it by hand. you may be able to feel or hear it.
take to a shop and let someone ride with you.
a mechanic should now what a bearing sounds like.
like I said, CV's are pretty robust, with the boot intact and with the low angle on the joint, its probably the bearing.
rekstein1 04-12-2017 10:50 AM
Update, Ronnie is correct in that I lifted up one side at a time and spun the wheel from the outside. Didn't hear anything. No grinding, wheel seemed to move freely.
I can't imagine by lifting the entire rear both sides. Having someone else spin the wheel and then placing my hand on the cv by the trans or the wheel the result would be different. Short of a stethoscope and a hunch its seems to be a problem of subtle nature .ALthough its loud in the cabin, not so subtle.
A more experience person should look at it as opposed to me throwing parts at it.
Does anyone have an idea what it would cost to have a mechanic replace the wheel bearings, or do they just replace the cv's as well because they are there?
I am going to try the feel thing as ROnnie suggests this weekend before I make a final decision as to how to proceed
As far as the sound that some people have asked about it not a grinding sound. Its just very loud in the cabin as my original post stated. ALso the sound happens at 30 to 50 mph. Maybe this is why spinning the wheel by hand is not diagnostic. WIth the clutch out it sound like the wheels are the source
Everyones final thoughts would be appreciated
RichSmileWavy stuck on the sidelines for now:Dand pissed
Ron Ac fully installed was looking to charge it soon!!!!!!!!!!!!!!
Bob Kontak 04-12-2017 11:17 AM
You never know. You are probably correct if there is a genuine mechanical issue. I just like to get up in there.
Another thought, rub you hands around the outside of the tires and check for anything that resembles cupping. That can make lots of roaring noise.
whiz05403 04-12-2017 12:11 PM
I had a significant noise coming from the rear end of the car a few years ago. I replaced the bearings, noise still there. I replaced the axles/CV joints, noise still there. I replaced the tires (that looked totally normal) noise gone!!
T77911S 04-13-2017 03:25 AM
you probably wont hear or feel it spinning it by hand. you need to run the engine and put it in gear. even then it will be subtle. you really have to just know what a bad bearing sounds like and what a CV sounds like.
driving the car the bearing is going to be a "roaring" sound. CV's usually click or pop. again, never heard a bad 911 CV.
putting it on stands and checking really just verifies which side and the fact it is not a tire.
just went thru this with my 930. left side was bad but did both.
I also did my CV's before this. I had one CV that had pitting, no sounds from it and I certainly did not suspect it was a CV,.
if you are still in doubt, take a mechanic for a ride.
rekstein1 04-21-2017 03:28 PM
Update
OK here it is the prize goes to Jesse 16 and Charwood77.
Got a call from the local Porsche guy near me who's shop I pulled up to must have had 9 or 10 Porsche' inside. Looked like I was at the right place.
Left the car and he did a complete look over. Quote"The left rear bearing is screaming and it also appears a couple of cv boots are broken,
Here is where it gets interesting. He could replace the (1) outer bearing, i guess there is two? on one wheel for $600. The boots on the current axle could be replaced for another $300 without the guarantee that once he looks at the cv that there might not be a a problem and its not a simple boot replacement. Car has 150 k on it. and I have no history prior to 100K miles
Hmmm. Thinking about what charwood said in that the other side might go in 500 miles or so. For $600 for 2 new cv's upgrade axles and 300 for all bearings for both sides and my time I thinking its a better way to go
Am I wrong here?
Also they said that the brake pads were getting low just wondering did them at 40,000k miles ago is that normal wear rate?
Looking forward to everyones thoughts and bye the way who has a spare wheel bearing puller set up that I can borrow or rent?SmileWavy
sugarwood 04-21-2017 05:04 PM
If you can afford it, just get everything done. It's nice to keep both sides the same.
Jesse16 04-22-2017 02:41 AM
replace both and since you're not DIY ing you can likely sell the two split boot axles on Pelican to help a little. You could rebuild both for cheap but that's a different level of effort, mess and trust in old car parts. Sounds like you'll be back to smooth running soon.
rekstein1 05-04-2017 10:43 AM
Trying to rent or borrow the Sir tool hub puller thing/ or the other tool. If anyone can do this please pm me. To Rusnak, your mailbox if full and I can't send a message to you.
Just trying to get in and out without the drama during the repair appreciate anyone who can help
