leather repair?
so I'm trying to load one of my bass cabinets into the back (yes, the 911 serves as a truck now and then) and it pushed against the B-pillar, stretching the leather covering and making a small sort-of-rip spot. Any way to mend this or shore it up? It isn't an area that should get any wear (unlike a seat, and I'll use my smaller cabinet next time), and I'll Lexol the whole thing but I figure there might be some magic goo I could apply that would seal the area.
Maybe you could try the stuff they advertise on TV? Liquid Leather or something like that. If it's a small area it might be worth a shot. Plus you would have the bonus of being able to go to the "As Seen on TV" store at the mall. Plus, if I remeber correctly that stuff did quite a job when that heartless person on TV took the 14" Ginsu and hacked up that beautiful "leather" sofa.
In all seriousness, I did a search on Google for leather repair and it looks like there are several options around $20.00. Good luck, Jeff |
Not Quite Banned
Todd, you may spend longer trying to repair rather than simply recover that piece. I did both in my cab with material from Autos International. Material was < $20, pair of scissors and contact cement. Quite easy to recover.
good luck,
Thomas Owen 1972 911T 1972 911S |
911 user
If you can get behind the rip. Place a small piece of tape (duct, gaffer, carpet edging or w..h.y.) behind the rip and pull it into shape. I've repaired upholstery rips like this.
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
Todd:
Depending on how big it is, I have a couple of suggestions. First, many of the larger auto supply places (including JC Whitney) have a product that will fill and cover upholstery holes very nicely. (Hockey Fan is describing a variation of this product.) They even have simulated grain to blend with the grain of your existing material. Take a look here: JC Whitney The other alternative is to bring a company in that will do a professional version of what the DIY kit will do. The PO of my car had drilled a large hole through the lower part of the dash for an alarm keypad. I had a company come in and fill the hole and match the grain. Unless you're *really* looking for the repair, it's virtually invisible. Good luck. Scott
1984 Targa |
I did a seat repair a few years back with a product made by leatherique, while not perfect it did do a very good job. You will need to send them a swatch of material for a color match. You simply glue a reinforcement piece of leather behind the repair and fill the remaining gap with this colored goop. I would recommend any of their products (no affiliation). Think the web site was leatherique.com.
Walt 82SC 3.0 81SC 3.6 |
