Lower dash trim
Hi,
What is a typical upgrade on a old tired lower dash trim for our cars?
Anyone have any pictures to share?
Is there a kit that someone sells?
Thank you.
1974 911 coupe 4 speed
Old 01-14-2018, 08:05 AM
Are you talking the knee pads? Can you post a picture? Those are replaceable.
Old 01-14-2018, 09:21 AM
I am resurrecting this thread as I would like to know the same thing. Basically my ashtray bit the dust and I need to fill the gap so is there a solid one piece lower trim I can put across and remove the rest of the trim?
Old 04-27-2018, 04:40 AM
I still haven’t done anything but definitely don’t like the factory setup.
Old 04-27-2018, 04:55 AM
Check out the continuous aluminum piece offered by Rennline. That's the route I had planned to go, but they don't offer a version for the 87-89 dash. I think it looks pretty good.
Rennline Lower Dash Delete Cover-Rennline, Inc.
Old 04-27-2018, 05:48 AM
Grappler
Rodsrsr's Avatar
Rennline makes some aftermarket pieces.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 04-27-2018, 09:18 AM
puddy's Avatar
^^Ditto to that, I think the RENNLINE stuff looks really good too, but I think you have to loose your glovebox. I'm not willing to give that up yet.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-27-2018, 09:47 AM
Maybe I was not using the correct lingo. I was refering to where the ashtray is, the vinyl wrapped lower dash, under where the accessory trim is.
Old 04-27-2018, 11:00 AM
Yes. Rennline has a replacement...
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-27-2018, 12:33 PM
Awesome! However I have a 71. I need to call to see if it fits...
Old 04-27-2018, 02:25 PM
With a few woodworking tools make your own. Upholster, paint or leave natural.
Old 04-27-2018, 04:28 PM
Science is NOT optional
rbogh901's Avatar
Those are called knee pads. They can be read upholstered. Also you can get one from an early car with the continuous one piece knee pad to eliminate the ashtray which is kind of cool.
PCA member since 1993
Old 04-27-2018, 05:10 PM
4flyboy's Avatar
You can also prep it and re-dye it to look brand new whether vinyl or leather. Looks the business.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 04-27-2018, 08:27 PM
SWS911's Avatar
I think early '69 only had the "split" kneepads that could be recovered like the earlier one piece kneepads.
I have a one piecer for my '71.
Old 04-27-2018, 08:44 PM
Seems it may not fit.
Per Rennline "Due to that being a very different dash board it is very unlikely that would work!"
The SWB single dash piece it fetching over $400 on ebay... does anyone have any other ideas?
Old 04-30-2018, 01:10 PM
yes, buy an ugly right or left section of the kneepad from a year that will work for you, cut a section to fit that area, re-vinyl all sections to match and bolt it in.
Old 04-30-2018, 01:27 PM
