Spray / brush epoxy coating for oil tank?
Hi. Who here has actual knowledge/ experience in putting an epoxy (or better materials?) coating on the exterior of an oil tank? We have a specially modified one that needs to have that extra layer to seal it up
thanks for sharing !
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
After getting my blasted & ultrasonically cleaned oil tank back from Pacific Oil Cooler Service, I brushed a few coats of POR15 on one of mine. The consistency is thin enough that even brushed, it lays down flat w/out brush marks. It is shiny though... When installed, the tank doesn't see any direct sunlight, so I didn't topcoat it with anything.
There are lots of differing opinions about POR15 out there, but in that instance for me, it's worked out great - super durable so far. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Fleabit peanut monkey
Powder coating is pretty slick. As Tom says you don't see it, so...............overkill?
The coating place can tape it off where you don't want the coating. Better yet, get some of their tape from them and do that part yourself if they guide you. I like POR15 but have not used it enough to say I swear by it.
1981 911SC Targa |
Dave i would walk it across the street and have bill powder coat it and be done with it,tell him kevin sent you,haha.Hope all is well.
Sent from my SM-N910T using Tapatalk |
I cleaned mine down to bare metal, prepped it properly and brushed on two coats of POR15. It's as hard as nails.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
Cars and Cappuccino
I am stripping mine now and I am just going to clear it. I like seeing the brass neck and the welds.
Powdercoat can't touch DuPont Imron for tough. Hard as nails and sticks forever. Why they use it on bridges.
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Hi Dave,
I use a catalyzed epoxy primer on mine and then cover with a Satin black paint. Works great!
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
