-   -   Passenger Window Control (http://forums.pelicanparts.com/porsche-911-technical-forum/954036-passenger-window-control.html)
Dreamer52 04-20-2017 04:17 PM
Hi All
I can lower my passenger window with the driver's side switch but must use the passenger to raise it. Any ideas?
Thx
Alex599 04-20-2017 04:28 PM
I would say that it's most likely the switch. Have you checked if all the wires are well connected?
Jesse16 04-21-2017 05:17 AM
If the switches are old, I would get a set of 3 (the OEM ones) on order anyway as you will at some point need them. If you are sure they are hooked up same as when they did work, then almost surely is a bad switch. In ten years and 100k of driving I've replaced mine at least once. They are only mildly robust in design.
Dmitry at Pelican Parts 04-21-2017 08:40 AM
Take a look at the link below from our site, it'll help you address the issue.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
