3.2l Oil pressure gauge
Does anyone have the correct part number for a 3.2L oil pressure/temp combo gauge?
TIA
Old 04-21-2017, 05:18 PM
RETIRED
Joe Bob's Avatar
The gauge and sender need to be matched. Was there an engine change? Best to call Glen Sager at Pelican. Give him the gauge part # and he will tell you what sender should be used. If it is the one called for in the book, the sender may be bad. If incorrect, replace with the right one.
What is it doing? No read or grounding out to max or just acting weird? Depending on symptoms it could be a wiring issue.
2012 ML350 3.0 Turbo Diesel
Old 04-21-2017, 08:51 PM
