Identify these tiny parts...?
I took apart the interior of my '84 the other day, and found a few important-looking bits rolling around. Anyone recognize them? My first guess was some parts from my Wevo shifter, but I didn't notice anything external missing...
The last one was taken off of my air intake, and I believe it was screwed in there solely as a support for the aftermarket conical air filter. Probably just something the shop had lying around? http://ensaster.com/pics/vehicles/smaug/random-bits.jpg |
The middle one looks like half of the allen headed set screw for the shift linkage coupler to transmission linkage under the access panel in front of and between the rear seats.
The whole things looks like this; http://forums.pelicanparts.com/uploa...1492815374.JPG |
The short allen-head plug also looks like it plugs the air injection port in the heads that have air injection.
The rubber cone looks like the locating stud for the air filter housing.
Yahtzee! 28 - Part number 993 110 321 03 - bonded rubber buffer
http://ensaster.com/pics/vehicles/sm...ox-diagram.png |
Got a close shot of the bottom of the hex screw...It doesn't seem to be sheered off, but it's hard to tell much of anything.
http://ensaster.com/pics/vehicles/sm...bit-bottom.jpg |
now THATS a good pic.
you have set the standard. no more blurry pics or pics from 4ft away asking what is this |
Fetzer Valve bearings and mounting bits.....
I think I solved the mystery...This would explain why my shifter got so rattly in the last week or two:
https://www.wevo.com/Products/ShifterProducts/ShifterImages/WEVO_915_Shifter_INSTRUCTIONS_2009.pdf 25 - LC 026B 09 M - WEVO PLUNGER COIL SPRING 26 - 48200 - M10 X 10 SOCKET SET SCREW 27 - XT_144 - WEVO PLUNGER BUTTON |
| All times are GMT -8. The time now is 08:32 AM. |
