-   -   Need help finding body plug part number (http://forums.pelicanparts.com/porsche-911-technical-forum/954383-need-help-finding-body-plug-part-number.html)
moparrob 04-23-2017 08:54 PM
I just stripped out my rear seat area and want to replace the two rubber plugs under the rear seats but I cannot seem to locate the plugs or the part numbers for them. These are the plugs (not my car though)
http://forums.pelicanparts.com/uploa...1493005926.jpg
Does anyone know where to get these or the part number or size?
Much appreciated.
cabmandone 04-24-2017 06:45 PM
I think I have 1 or two of those plugs in my shop. Measure the hole and let me know what size it is. If I have them, they're yours.
moparrob 04-24-2017 07:11 PM
Thanks, that is very nice of you. The car is at another location so I will stop by tomorrow and measure them. I never knew they would be so hard to locate.
:confused:
Bill Douglas 04-24-2017 10:03 PM
Wow, the strippering/cleanup went well.
moparrob 04-24-2017 10:42 PM
That picture is not of my car. This is the thread to my endeavors from last weekend:
http://forums.pelicanparts.com/porsche-911-technical-forum/954267-my-experience-citrus-stripper-what-now.html
Luccia at Pelican Parts 04-25-2017 08:42 AM
If you don't have any luck give us a shout and ask for Bruce. He might be able to help you. 1.888.280.7799. Good luck!
hotdogwater 04-25-2017 09:27 AM
I stripped my interior and had to replace all of the plug inserts. On my car 1970T these were metal discs that are glued in with seam sealer. What year is your car?
Couldn't find part number (not even shown on parts diagrams I don't believe) and posted here but go no response. I did have a shop cut me some and I should have some left over if you can't find any or find you need a lot of them ( think it took 12 or 13 to do my entire floor pan and rear seats) let me know. Most all of my plugs had rusted so I replaced them all when restoring the interior just sealing them in with new seam sealer.
Here is the post I made about the strip down in case you are going that far. http://forums.pelicanparts.com/porsche-911-technical-forum/879363-floorboards-interior-stripping-2015-edition.html
moparrob 04-27-2017 01:42 PM
Well now I am a bit embarrassed. It ends up those are not body plugs. There are depressions in the metal Seat pans that were filled with some sort of black tarry substance that I thought were plugs. Thanks anyhow.
hotdogwater 05-01-2017 09:41 PM
Are you sure there isn't a flat metal disk sealed inside that black tar? Not sure you read all the replies above or maybe your car is different but most of these are filled in with seam sealer (the black tar stuff you mentioned) and a metal disc/plug. Maybe not fair to call it a plug but all of the drain holes in my 70 911 had discs sealed in them. The only real rust I found in my floor pan was in these plugs. If the sealer is hard and brittle its' probably time to remove and replace the sealer and the disc/plug if their is rust starting.
moparrob 05-01-2017 10:22 PM
Well I'm not 100% sure but it sure seemed like it. I will need to wheel the car into the the sunlight next weekend and take a heat gun to those areas to see what lies under the goop. Thanks for the input.
