Harpo's Avatar
Zuffenhaus Products
Good morning Pelicans
I have a 74 that was built in late 73. I purchased a ST steering wheel and late hub from Zuffenhaus and when I went to transfer the horn contact / turn signal cancel ring there were no threads in the bottom of the late hub to screw in to. Either I should be using an early hub or the hub is defective.
I have left a few voice mails and sent a few emails but still no reply. Short of knocking on their door is there another way to get a hold of these guys?
I'm considering using epoxy to hold the screws in place. Suggestions?
Old 07-06-2018, 04:09 AM
Registered Minimalist
75 911s's Avatar
If I follow you correctly, the hub from Zuf is a decorative cover. It eliminates the accordian cover on the Momo saftey crush hub. Since the Zuf wheel is a momo prototipo (mostly) it still needs the momo hub. The momo hub has the threads that hold the turn signal cancel in. The steering wheel bolts up to the hub, through the decorative cover holes and into the angled momo hub.
I think ZUF is sort of mis labeling it, by calling it a 'hub' it should be called a hub cover. Again, you still need the actual structural crush hub underneath.
Can you post a pic of the bottom of the zuf hub? because my decorative cover is from a different supplier so I could be way off base here.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 07-06-2018, 06:14 AM
Been here a while
the zuff guys are common contributors here, I'm sure they would comment. Of course it's a holiday week and summertime, so it is always possible they might be slow to respond.
why not PM them thru pelican: eimkeith
looking for 1972 911t motor XR584, S/N 6121622
Old 07-06-2018, 06:23 AM
Harpo's Avatar
The hub is a solid piece of aluminum. It has the correct splines on one end and the 6 or 8 M6-1.0 threads on the other end to attach the wheel. I will post a photo tonight of the three holes for the three factory screws that attaches the horn contact/turn signal cancel ring.
Yes, it is a holiday week and I should be more patient
Old 07-06-2018, 08:23 AM
Harpo's Avatar
Here is the back of the factory wheel with turnsignal cancel and horn contact ring
Old 07-06-2018, 04:34 PM
Harpo's Avatar
Here is the back of the new hub
Old 07-06-2018, 04:36 PM
Harpo's Avatar
New hub with ring but screws have no threads to grab on to
Old 07-06-2018, 04:38 PM
Harpo's Avatar
I will probably just epoxy the screws in place. Where do I ground out my horn button
Old 07-06-2018, 04:41 PM
BURN-BROS's Avatar
The three holes are there correct. They are just not tapped?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
BURN-BROS's Avatar
nevermind, just saw the lower pic
Burnham Performance
Old 07-06-2018, 04:42 PM
BURN-BROS's Avatar
The brass ring you transferred over should have the spade to mount the wire no?
Burnham Performance
Old 07-06-2018, 04:44 PM
Harpo's Avatar
Yes, the ring has a tab but no tab for ground. I think I will go buy a second washer to go on the column and I will drill a hole and solder on a ground wire.
Old 07-06-2018, 05:14 PM
Been here a while
Usually momo wheels and similar that come with a horn button like that have a ring that goes between the hub and the wheel to hold the horn button and it has a tab to allow the ground wire to attach.
Old 07-06-2018, 05:31 PM
Harpo's Avatar
That looks more professional than what I'm going to cobble together
Old 07-06-2018, 05:40 PM
BURN-BROS's Avatar
LOL, Honest man.
What's the front of the hub look like?
Burnham Performance
Old 07-06-2018, 06:02 PM
175K911's Avatar
If it were my car I’d get screws one size bigger but same length then tap matching threads into the hub. And I’d probably over engineer it and use allen button head screws too.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 07-07-2018, 04:22 AM
Harpo's Avatar
Old 07-08-2018, 01:49 PM
