carreradpt's Avatar
Death Valley (STUCK) Help!
I'm on a road trip and my alternator I think has gone to hell. How appropriate here. Anyway the local mechanic here has determined that my battery is not taking a charge. It is now on the machine to charge up to 100%. The local guy thinks that I can make it 120 miles to Las Vegas ( Porsche shop) running only on the battery and not using anything but my V1. The Porsche dealer in LV thinks that I'll only make 30 maybe 60 miles. Help!! Should I go for it or just take a tow from here? Pahrump is 60 miles halfway there with towing. The local tow truck just left from here and won't be back until late afternoon. I have AAA plus so 100 miles is almost free. Do you guys think that I can get 120 miles pretty much a high speed run?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 01-22-2003, 09:11 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Why not buy a second battery just in case the original doesn't make it. You'd think another battery would be cheaper and faster than a tow truck.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 01-22-2003, 09:14 AM
Friend of Warren
I concur with the second battery.
Kurt V
Old 01-22-2003, 09:17 AM
Chuck Moreland's Avatar
I had the same problem 300 miles from home on a mother's day sunday. I bought the biggest second battery I could find and headed home.
Fist battery got me about 100 miles. Second battery got me home and never did run dead.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-22-2003, 09:18 AM
You do get a little warning that the battery is almost dead.
While charged the alternator light will glow brightly. When the battery is almost depleted, the alternator light will begin to dim but the car will run another 10 minutes or so. Enough time to pull off the highway and get to a gas station (to recharge the second battery if needed).
Old 01-22-2003, 09:20 AM
carreradpt's Avatar
Thanks for the quick responses. I never thought of that idea about another battery. My cell phone is at home so I am going to ask the visitor ctr to send help if they don't hear from me in a certain time. I'll have to see if they have batteries for sale. Thanks again.
Dan T
'85 Carrera
Old 01-22-2003, 09:44 AM
pwd72s's Avatar
Go for the highest CCA number you can find...
Old 01-22-2003, 09:51 AM
I'd check the alternator bearings first, if they're failing you could lose your fan cooling, fan, fan shroud and maybe the engine (from overheating). Pull on the fan with the engine stopped plus listen to it with the engine idling. If it is loose or there is any run out or scraping it's time for a new generator or flatbed wrecker to a repair shop. If you're handy you could do itthere. You could call either Pelican or another vendor and maybe have the parts there by morning. Do you have tools with you? Good luck. Jim
Old 01-22-2003, 10:00 AM
jabb's Avatar
I went about 120 miles on my battery then switched with a buddy that was following me, when we switched my battery still had enough juice to start his 911. Either get a second battery
or one of those Jumper Battery packs they sell at autopart stores find the biggest one they have..... Make sure its charged....
Good Luck
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 01-22-2003, 10:20 AM
Second battery and a miniture solar recharger that can be charging as you drive, should you loose the charge on the first battery. Good luck.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 01-22-2003, 10:43 AM
Second battery idea is the right one! Worked for me in 1984 with my Fiat 124 Spider. Got me across Kansas and Missouri - then I turned on the headlights at dusk and - well, just get to whereever you're going before dark!!!! Good luck!
RKC
1987 Guards Red Targa
Irrationally exuberant
ChrisBennet's Avatar
For future reference:
1. Does the heater blower in the engine compartment run all the time (78+ cars)?
2. If it doesn, would pulling the fuse to this blower make sense in a dead alternator emergency?
thanks,
Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-22-2003, 11:18 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Second battery is the ticket.... make sure they charge the second battery to 100% as well b/c they do discharge as they sit.
BTW: This reminds me of a story. A couple winters ago me and a friend from NJ packed up his van w/ our 2 400CC kawasaki's and headed to FL. to meet his brother and do an Iron Butt ride (1000+ miles on a motorcycle in 24 hours....documented). About 80 miles into our 1000 mile adventure, my battery dies...faulty alt. Between the 3 of us, we swaped batterys every 100 miles (or every gass fill). I unplugged the headlight and bought a 6V lantern and duct-taped it to the top of the handlebars for the rest of ride to save power. By mile 900 or so, my 'friends' just about hated me. Finished mile 1000 in 23 hours, 45 mins.
-Charlie
Old 01-22-2003, 11:19 AM
Where in Death Valley are you? Furnace Springs? Man that place can be erie almost like your on another planet, at least it's winter. Let us know how you make out
Good luck and God's speed
Old 01-22-2003, 12:04 PM
Right on responses! Second battery is the insurance. If you can get to a Wahl Mart or Pep Boys you can buy one resonably. I've cruised a long way with inoperative alternators. Recently I left my headlights on for 7 hours and the 88 cab started right up. (Faulty headlight dimmer switch somehow turns on the headlights when left in the left hand turn position with the ignition off.) A good battery can get you a long way! Good luck!
Old 01-23-2003, 11:47 AM
Send a message via Yahoo to RichMason
I did 7 hours with a dead alternator...
in my Mercedes diesel - doesn't need juice to run. Of course , once I got off the highway I had to use a flashlight out the sunroof to see where I was going since my headlights did'nt work. Southern Coastal Georgia - darker than any place on earth. By two extra batteries and return the one you don't use, heck you could return both of them once you get to LV if you buy from a major chain.
Rich Mason
87 951 for sale $5500
Old 01-23-2003, 11:55 AM
Calspeed's Avatar
Just in case you decide to go the AAA route. Some of the drivers are pretty cool about the 100 mile thing and will write you two tabs so that you can go straight through. Just make sure to give a good tip.
Calspeed
2008 Porsche 911 Turbo - One of the Baddest 997 Turbo in the SF Bay Area
1985 Carrera Cabriolet - The 2nd Baddest 911 Cab in the SF Bay Area. (sold in 2006)
Old 01-23-2003, 01:07 PM
Senior Member
john_colasante's Avatar
Anybody know how this ended up...
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 01-23-2003, 01:23 PM
Somewhere in the Midwest
MotoSook's Avatar
he hasn't reposted, so he must be wandering around in the desert or got picked up by a UFO.
Old 01-23-2003, 02:07 PM
Hmmmmm no response, Where was he headed?, To Sin Town!! ie women, booze, gambling more women. I don't think you would here from me either.
Old 01-23-2003, 03:36 PM
