Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Eng-o-neer
Tremelune's Avatar
I can second that...I think mine are currently polygraphite and they squeak and groan like crazy.
Old 05-09-2017, 11:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
wiring diagram
So I've been trimming the wiring diagram for everything that I need.
I tried to remove every single wire that I think it's useless and with all wires and relays off I think I loose some good grams!!
Pic of the diagram
Old 05-10-2017, 01:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
Big benefit of coil's is droop travel with higher rates. Gravel cars and even tarmac rally car's need droop travel or stand to loose out on very important traction. Stiff t-bars have a huge image on total droop.
Old 05-10-2017, 05:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
Max Sluiter
Flieger's Avatar
Droop doesn't care what type of spring it is, unless you let it come unseated. Spring rate and corner weight will give you static deflection which is also the droop travel. Maybe you are talking about rising rates in which case yes, you will get more droop than the equivalent linear spring. But if you use a linear rate coil spring you don't get any more droop.
If you let the main spring come completely unloaded then even though the wheel may be on the ground you've only got 20 pounds on it. I guess that's better than nothing and if you are in deep snow or something it might still act like a rudder.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 05-10-2017, 09:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
SWS911's Avatar
Make sure you have the right wiring diagram. I noticed you said a "70", but with that parcel area and oil tank hole that is a '73.
Old 05-10-2017, 09:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
You are right!! It's a '73 911E
Old 05-11-2017, 01:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
So, about the engine...
It is an original from 73, MFI, one piston and head is completely destroyed.
So since the engine is opened it will have a new crankshaft STD, 2.2S piston and cams, and we'll mesure and test every other material to check what damage it have if it have any.
Pics
Old 07-03-2017, 03:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
So I've visited the car, the front and rear fenders are done and fitted, doors are done and maybe next Saturday will be put in place. The engine will start to be reconstructed in August.
Some pics
Old 07-17-2017, 12:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
Eng-o-neer
Tremelune's Avatar
Is it weird that I'm into that primer green color?
Old 07-17-2017, 07:00 AM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
H-viken's Avatar
Originally Posted by Flojo View Post
do you retrieve the torsion bar up front before paint?
Not sure I understand what you mean as the car is on a dolly with the a-arms removed?
911E Coupe -70
Carrera 3,2 -84 Sold
Old 07-17-2017, 09:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #30 (permalink)
Really like the color too... But, at the end, it will be white
Old 07-17-2017, 03:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #31 (permalink)
Send a message via ICQ to Sebscst
I think he meant the sway bar.
83 944 ( R.I.P.)
78 911 st backdate (3 years and counting)
87 944
Old 07-17-2017, 05:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #32 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Restoration.
Originally Posted by BernardoEsteves View Post
Hello, I just signed this forum, but for long I've been following some posts. It turns out that it's my turn to create a new post since I'm restoring my Porsche from 1973 to a lightweight one in a small budget project. I need help from all of you since I don't have a lot of experience in this area...
Some photos of everything that was done until now.
How it started
Unmounted and cleaned everything
Replaced rusty parts
With the primary after sandblasting
And trying the new doors.
This is a slow going project with the final purpose of racing.
Trying to do now all fiberglass panels, see if all fits and then start buying parts to start mounting the car.
What do you think i should do next?
Poetry in motion!!!!!!!
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-17-2017, 06:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #33 (permalink)
H-viken's Avatar
That makes a lot more sense. And yes, it should've been removed
911E Coupe -70
Old 07-17-2017, 09:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #34 (permalink)
Almost done with all fiber, just missing the back lid and mount the door locks.
Meanwhile we've put back all axles to take the car to the body shop to repair all little rust details we found and do the rollbar.
Old 07-24-2017, 03:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #35 (permalink)
OK, I'm almost done with fiberglass.
What's next:
  • Need to finish the door hinges, and see if it fits.
  • Rear bonnet, need to find a mold.
  • Front bonnet I don't know yet if I do a new one (the one I have it's too heavy)
  • Do the coconuts for front fenders
  • Rear Lights fitting in fiberglass
It is all is left from FG.
After is going to a bodyshop to do a proper rollbar.
Old 08-07-2017, 01:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #36 (permalink)
Need to finish the door hinges, and see if it fits. - Door in place
Do the coconuts for front fenders - Done, need small adjusts
Rear Lights fitting in fiberglass - On process
Old 08-16-2017, 06:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #37 (permalink)
Doors - Done with frames on
Rear Lights - On process
Front Light (blinkers) - On process
Front Light - Coconuts done, need to test if it fits
It's been a long way, and working with fiberglass it's not easy. I can "see light in the end of the tunnel", I hope this Saturday the car is away from that FG place and can travel on Monday to do the rollcage and small adjusts on the body.
Old 08-18-2017, 04:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #38 (permalink)
FINALLY the car is done from FG shop.
Waiting now 2 weeks to go to the rollcage shop.
Some pics
Old 09-04-2017, 02:26 AM
  Pelican Parts Technical Article Directory    Reply With Quote #39 (permalink)
Just to update Brothers together yey
Old 09-25-2017, 12:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #40 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
