What do I do with the return fuel line?
Morning all
On a 1970 911T and my fuel pump is at the rear and has no return line provision. Only in and out As far as I can tell from the parts diagram, the return fuel line goes to the bent pipe connection on the tank which is #7 on the diagram #3 is the line to the pump So in my case where I have no return line, what do I do with #7?? Thank you
And pic of the pump
Return line not needed with carbs. At the tank, plug the return line port. However, needed with MFI.
S |
