Selecting your test procedure........
Phlown, Use a test light instead. Remove the CSV from its mounting and watch out for the washers and o-ring. Test and confirm that fuel is being delivered by the CSV during cranking (start). If you are not getting fuel: a). CSV could be defective. b). CSV not getting energized during cranking/start. c). CSV not getting fuel due to fuel delivery. d). TTS not operating. e). There is an open wire in the circuit. f). Your non-start problem could be unrelated to the above. Keep us posted. Thanks. Tony |
I think it's probably f). I've started mine without the CSV, you just have to crank and crank until it starts.
You put in a new starter? I'd go back and check all the wiring, connectors and grounds around the starter and in the engine bay - I once had a loose connector on the CDI box after I'd been messing around in the engine bay. You could use a timing light on the leads and see if you are getting spark. Hopefully it's just something really simple. |
| All times are GMT -8. The time now is 05:09 AM. |
