-   -   Question regarding tail lamp lens gaskets (http://forums.pelicanparts.com/porsche-911-technical-forum/95503-question-regarding-tail-lamp-lens-gaskets.html)
Ron Egan 01-24-2003 10:31 AM
I am in the process of replacing my tail lamp lenses with Euro lenses. The original gaskets look pretty rough and as a result, I plan to replace them. They look as if they are glued in place ? Any tips on how to remove them without destroying the lamp housing ?
I assume it is necessary to glue the new gaskets ? What should I use as far as an adhesive ?
Thanks,
Ron
nick-moss 01-24-2003 10:40 AM
This subject was covered a couple of days ago here
RoninLB 01-24-2003 03:26 PM
new lens gaskets can be PIA.. seems they are always to thick. I tried 2 different dealers, SOS..............Ron
Early_S_Man 01-24-2003 04:06 PM
3M 8011 Black Weatherstrip Adhesive works very well on those gaskets. Get some 3M Paint Cleaner along with it at your local automotive paint supply store ... to clean up afterwards with, and you won't have to worry about harming your paint cleaning up the bits of adhesive that squeeze out after the lenses are tightened down. Clean it up before it hardens!
jtratza 01-24-2003 06:58 PM
I replaced the lenses and gaskets a year ago or so on my 1987 and hope to never do it again. What started as a Friday afternoon project took until Sunday to complete. I tried to remove the entire unit rather than just replace the lense. Dumb idea. The screws stripped and replacing them was a nightmare. The new seals are larger than the original but I figure in about 10 more years they'll settle in. Hopefully.
RoninLB 01-24-2003 07:06 PM
thanks for relaxing me...........Ron
