Replace IMS bearing on a 29k 2002 carerra?
I just purchased this unused like new carerra. I had originally planned to install a new ln ims bearing. Both the shop who did the pre purchase inspection and the shop I am taking it to suggested not replacing the bearing. They thought you could check the exterior for leakage and only fix it if you need to. As a long time owner of a 78 911 sc targa, I am aware you might agrivate some problems by very low usage. The last oil change was in 2015 with 2k milage since. I do not want to roll the dice on a very expensive motor. Any good advice?
Old 05-09-2017, 09:12 PM
If you replace it you'll spend $2500 If it breaks you'll spend $20000
Pretty simple math
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 05-10-2017, 04:24 AM
RETIRED
Joe Bob's Avatar
Look at the LN Engineering fix.
2012 ML350 3.0 Turbo Diesel
Old 05-10-2017, 05:56 AM
From my limited research on the topic, I would strongly consider having it done. You are in the range of the worst (single row) bearing, and also the worst conditions for the bearing - a garage queen.
Stagnant oil, short trips, just sitting seems to be conditions ripe for damaging the IMS bearings. Cars that are run regularly, see full operating temp often so the water boils out of the oil, and the oil is changed often seem to have much fewer problems. That's all unproven theory but it makes sense to me.
Matt - 84 Carrera
Old 05-10-2017, 06:04 AM
Spiderman
Jesse16's Avatar
I guess if you planned to keep it garaged and not drive it then leave alone. But every time you take it out I'd be sweating every new mystery sound coming from the motor. Too nerve wracking for me and would ruin the fun.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-10-2017, 06:15 AM
Changing it would also help with selling the car. I would do it.
Old 05-10-2017, 06:26 AM
MBAtarga's Avatar
With that recommendation I would find another shop!
Mark
'83 SC Targa - since 5/5/2001
Old 05-10-2017, 06:40 AM
Weekend Mechanic
vulcan300's Avatar
I would do it if I were in your position. It is cheap insurance against a very very expensive engine failure. You can also take care of the clutch at the same time if it is worn enough to warrant replacing. Then you can drive the hell out of it and just not worry. Who needs stress when out for a nice drive in a cool toy.
86 911 Carrera Targa
Old 05-10-2017, 07:16 AM
SC-targa's Avatar
Lordy, replacing a clutch at 29,000 miles? Who abuses the machinery that much?
Should easily get over a 100 k out of a clutch.
Old 05-10-2017, 08:24 AM
Yeah, the IMS is one of those things I would just have to do if I had a car with it. Especially the early IMS.
If the IMS comes apart the first time you find out could cost you what the car is worth. It would truly stink to have a perfect car worth not much more than 20k that needs a 20k dollar motor.
Old 05-10-2017, 08:27 AM
What models & years are affected by the IMS bearing problem?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-10-2017, 10:37 AM
1999 thru 2008-ish, 996/ early 997, boxsters and caymans. just google IMS and M96 engine. And yes, for peace of mind i would replace. roll of the dice if you don't and you will be pissed at yourself if it goes BANG next month.
Old 05-10-2017, 10:41 AM
97-08 Boxster & Cayman
99-08 911 (except turbo & gt3)
Matt - 84 Carrera
Old 05-10-2017, 10:42 AM
Counterclockwise?
It depends on how often you are going to check to see if it is leaking.
Rod
1986 Carrera
2001 996TT
Old 05-10-2017, 11:18 AM
Vendor
Fabspeed Motorsport's Avatar
Location: 155 Commerce Drive | Fort Washington, PA 19034
"An ounce of prevention is worth a pound of cure"
Unfortunately it's not the cheapest fix but when the alternative can be upwards of 10x the cost, it's worth it IMO. Peace of mind alone...
Beautiful 996 by the way!
Hamsa Naser
Hamsa@fabspeed.com
W: +1 267 742 3006
Old 05-10-2017, 11:41 AM
sugarwood's Avatar
You will get $2000 of that back in your increased resale value, so how about that?
1986 Bosch Icon Wipers coupe.
Old 05-10-2017, 01:23 PM
I have known two owners of M96 cars this year that the IMS failed. One was a Boxster, the other a 911. I Boxster owner was not sure his car was worth the fix and was upset. The 911 owner was going to fix at a cost of over $15,000. Get it fixed.
Old 05-10-2017, 01:28 PM
Harpo's Avatar
+1 on getting a new mechanic
Old 05-10-2017, 02:02 PM
Functionista
manbridge 74's Avatar
2015? Change that oil!
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-10-2017, 03:36 PM
Administrator
Dmitry at Pelican Parts's Avatar
Check out this video from LN Engineering on failed IMS bearings:
Link to the kit if you're interested: LN Engineering IMS Bearing Retrofit Kits
Old 05-10-2017, 05:00 PM
