European version 3.0 sc
Just out of curiosity, can anyone explain the difference in the European 3.0 sc that makes it put out app. 220hp versus the North American version's 180 hp?
Hugh |
Compression mostly. BTW, rated at about 204?
Higher compression, and it's not as big of a difference as you stated.
Check the fuel distributor part numbers. I believe the Euro models had a different fuel distributor that gave better power output as well.
Larger valves/ports, same size as '78/79, higher compression ratio, different fuel distributor, less pollution junk, no Lambda system, large port intake runners. Maybe some more that I can't think of now.
Thank you guys.
They are lighter too. No side impact bars in the doors, lighter bumper struts.
I'm guessing my ROW SC makes 220. It's a 930/10 204hp engine with cams and SSIs. |
US SC 930/17 180hp@5500, 265nm@4200 9.3cr, w/cat & O sensor, unleaded 91 octane RoW SC 930/10 204hp@5900,267nm@4300, 9.8cr, no cat, leaded 98 octane The only other differences are the tune, ie ignition & fuel curves |
Rev limiter in distributor on row as well.
| All times are GMT -8. The time now is 06:43 AM. |
