Send a message via AIM to 82SC
valve adjustment question...
so it is my first time...
i've read 101, bentley and the archives
after I do all of the valves and then turn the engine over a couple times by hand then recheck...i ALWAYS find one that is off...and it seems to be an exhaust rocker...
I think I have probably gone through the valves at least 8 times
any one have any suggestions?
at one point I did it...rechecked...everything checked out...
then I put my chain covers back on (from the cam swap)...and before putting on the valve covers I rechecked and found one that was too tight...
I am trying to get all the valves to have a snug "drag" feeling...why do I always end up with one or 2 tight ones???
MJ
could it be carbon bits on the exhaust valves????
Old 01-25-2003, 03:53 AM
Doug E's Avatar
Sorry if this is a dumb question but why were the chain covers still off?
I've done a few of these on friend's cars (and will be doing my own soon) and have used the 2 tool method: one loaded with .004 stock and one with .005 stock. Using this approach I've been able to find a good consistent pattern of tightness.
Doug
'81 SC Coupe
Old 01-25-2003, 04:01 AM
