CIS idle adjustment screw loose
I noticed i can grip the idle scew with my fingers and make it wobble side to side, as im doing that i can here a hissing noise as i move it. I sprayed some carb cleaner but has no effect on idle. It's a very audible sound, i took the screw out and the threads look fine, must be the inner threads are worn out in the throttle body itself. anyone ever experienced this problem?
Old 07-03-2003, 07:57 PM
I would be considering replacing it as this is a potential vacum leack area.
Ben
Old 07-03-2003, 08:03 PM
Original Owner
tsuter's Avatar
Silicone tape.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 07-04-2003, 06:24 AM
If you screw it back in does it still wobble? It may just be backed out too far. Maybe the PO backed it out to bring the idle up to compensate for something else? Mine was that way when I got it. I adjusted the CIS mix richer (CW) which brought my idle up then I screwed in the idle adjustemnt screw to bring it back down to 950 rpms and stopped the hissing.
John Adams
1980 ROW 911SC
Old 07-04-2003, 10:38 AM
sal sal is offline
Sal
sal's Avatar
Silicone tape
Silicone tape worked great! No more wobble.
Old 12-22-2017, 06:34 PM
